Click for CL Yachts 99X Click for Abeking Click for Burger Click for Westport Click for Delta
It's hard to buy a boat
Discussion in 'General Yachting Discussion' started by DAVID WEBB, Feb 23, 2025.
  1. captholli
    captholli Senior Member
    In The Bilge
    If I remember correctly the 8.2 had two different HP outputs of either 175 or 300 HP in 1986 or so. I had a couple of the 175 HP units that GM put Stamford alternators on for 75 K.W. A.C. generators on a vessel that the gens survived two years before being removed as one threw a con rod out the side of the block @ 2,ooo hours or so and started a fire and the second one kept having constant cooler failures with either the fuel cooler washing the cylinders with lube oil dilution or the oil cooler polluting the system, either way they were an abject failure as marine generator sets and weren't long on the market in that configuration.
    DAVID WEBB likes this.
  2. chesapeake46
    chesapeake46 Senior Member
    The Meridians sort of have a following too which makes resale a little easier
  3. DAVID WEBB
    DAVID WEBB New Member
    Florida
    Is a 1972 Hatteras 44' triple cabin EVER worth $89,000 ? Has 871 naturaals at 318hp, 1200 hours. Westerbeke 12kw gen with 136 hours--new. Two 16k btu and one 24k btu a/c units. The 24 is a mini split for the salon. Runs on 240v. Bottom paint 4/23, cleaned monthly. Windows replaced and rebedded. Recent hull and topside paint. Flybridge has aluminum top. Has upper and lower helms. Thru hulls and seacocks replaced (no date shown). A survey was done and the surveyor said that this was the nicest old Hatteras that he had seen in 19 years. The survey had several things that needed repair. The owner says that everything listed was fixed. States that was not a mechanical survey. What do you guys think? It's in the Pensacola area. About a 7 hour drive for me. Thanks
    If everything was showroom perfect, maybe.
    Call your insurance agent and ask him.
    Full coverage insurance will be hard to find.
    It is a good boat.
    It is not a fast boat.
    I'm not a WesterBroke fan.
    Possibly an old 32Vdc boat, I would check out any 24/12V conversions very well.
  5. Capt Ralph
    I'm not sure how that house a/c system would work on a boat in salt air.
    Inland only may be fine. Maybe others here can update my thoughts on this.
    Cruise at 18 kts?? Wide open throttle, down-hill and with the wind,,, maybe.
    https://downeyyachts.com/used-yachts-for-sale/1972-hatteras-44-44-tri-cabin-paramour_411941/
    https://boats-from-usa.com/hatteras/hatteras-44-12049
    I would give it a price between these two ads if you can get insurance for it.
    I feel that covid induced boat sale madness is over, there should be some room in this price.
    Your going to spend some bux on surveys up front also.
  6. DAVID WEBB
    Florida
    I doubt that I could get full coverage. Liability probably.
    I thought that price was on the high side. How much are surveys approx now?
    There is a 1975 Hatteras 43' double cabin with no flybridge in GA.--I like the looks of that. I don't need a flybridge--all about comfort, plus easier to single hand. Bad thing is that is on Lake Lanier in Georgia---land locked. I don't know if it would be a good idea to transport an old boat over the road to FL. It might identify some problems. I looked at a couple of late 80's Bayliner 4588's but getting owners to answer questions is like pulling teeth. It's like I should have to talk them into selling their own boat. I don't get it. NOBODY says "Hey, do you want to come and see the boat?" Thanks for the responses. It helps a lot!
  7. Capt Ralph
    Liability insurance on a boat is way different than anything else.
    Marinas are requiring more and more liability level$. Some full coverage.
    Fire and pollution are the main concerns that require a safe boat.
    Call some docks in the hoods you want to stay at and get their insurance requirements, Oh, More for a live-aboard...
    Call your agent and ask for quotes to meet these number$.
    Have a defibrillator nearby when you get these number$.
  8. DAVID WEBB
    Florida
    Yeah, Titusville requires 300k if you want to be on a mooring ball. A couple that I called are up to 500k for liability. I haven't called my ins co yet. Even private docks require insurance.
  9. Capt Ralph
    We have a 1978, 58' Bertram.
    My wife has to pay the tab behind my back. We don't have a defibrillator,,, yet..
    Some insurance companies require training by another captain.
    I don't mean to keep dumping on you.
    But you do need to ponder these things when shopping for a power boat.
    It is not like purchasing an old Buick station wagon.
    But for some reason folk think it is cheap living on a power boat.
    We did for over 20 years. It was cheaper in a house or two.
  10. DAVID WEBB
    Florida
    Hahaha, I get it. As you can see, I have been looking for quite a while, reading, asking questions, etc. Something that I read a couple of days ago about a raw water pump costing $3500 really got me thinking about how much I would be willing to spend to be on the water. I planned on using the boat and not just sitting in one spot, so I would probably find all of the problems on an old used boat.
  11. rtrafford
    rtrafford Senior Member
    Vero Beach
    It's a mixed bag, problems of old boats. Many of the problems are predictable and can be forecast into the schedule and budget, such as wiring replacements and plumbing upgrades. Joy of the "older boats" is that quite often they are quite simple to navigate and update. Newer vessels get into complex electronic systems along with plenty of bells and whistles.
    Older boats were often built to a very high standard, perhaps higher than some of the newer options. If it's built well, often times it can be a good path to your desired outcome. But you have to be willing to invest in the work needed by the old that was cut out of the purchase price of the newer.
    chesapeake46 and DAVID WEBB like this.
  12. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    Last time I priced a survey it was $22/foot, then you add the haul-out cost and the cost to hire a Captain if the owner is not available to operate the boat.
    As for liability insurance, I got $800k on my little center console, perhaps over kill but pretty cheap at $700 a year for full coverage @ $85k including the liability.
    For a bigger and older boat probably 4-5 times that.
  13. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Insurance is an absolute PITA these days. The older the boat, the worse it gets. I'm relocating my boat and so I have to redo my insurance. Must companies are wanting an updated, full out of water survey before they will even consider insuring, let alone provide a quote. I have zero concern about any survey findings given the condition of my boat. It's just another thing to have to coordinate and work through to satisfy underwriter's. Ugh!
  14. incoming
    incoming Active Member
    Cocoa Beach, FL
    A few more things to think about in terms of insurance:
    -It is very hard to find an insurer who will write you a policy if you don’t have 2-3 years experience running a boat within 8-14’ in length of the boat you are buying. Depends on insurer but the cutoff is commonly 10’ with some discretion to go up another foot or so with the underwriters permission
    -it is very hard to find an insurer who will allow you to keep the boat in the water in the event of a named storm. Some will require you to haul out. Some will require you to have a guaranteed haul out plan (see below). Some will require you to haul out or leave the SE for the whole season. Keeping the boat more than a mile from the ocean and a few miles from the closest inlet seems to help.
    -it is very hard to get a haul out if a watch for a named storm has been issued. There are places that will guarantee you a haul out if you pay them a very steep annual fee. Many of them are oversubscribed.
    -when you put these three items together, it makes it very difficult. Going liability only doesn’t help much because your boat can still break loose in a storm and take out a whole marina. And the experience thing is all about liability risk. Only thing you can do to improve your choices is buy a smaller boat then work your way up, and keep the boat some distance from the ocean.
  15. DAVID WEBB
    Florida
    I have Allstate for my cars and home and they use somebody for boats. For 300k liability on a 45' boat was about $450 per year.
  16. DAVID WEBB
    Florida
    LOL, Yeah, it's a boat, not a yacht---I saw that change.
