Click for Abeking Click for Glendinning Click for Burger Click for Westport Click for Burger
Imron Paint touch-up
Discussion in 'Carver Yacht' started by trmnewt, Jan 18, 2014.
  1. timjet
    timjet Member
    Tampa, FL
    I don't get it. Information on how to repaint aluminum is not difficult to get. Call your favorite paint manufacturer and simply ask them the product they recommend and the steps necessary to apply it.
    I would call Carver and find out the paint they originally applied then call the paint company.
    Advise from the paint company IMHO supersedes any advise on this or any other forum.
  2. gbarger
    gbarger New Member
    arkansas
    I was just asking iseau if he had the paint number/code as he stated he had done the above. If I have the paint number/code would just make my order go easier when I call the paint company.
    Quote:
    Originally Posted by iseau View Post
    I have a 466 Carver (probably same paint) I called Carver and they hooked me up with Midwest Industrial Coatings and they mixed up factory paint for a perfect match. I had to by a quart minimum but they also sold it in a spray can format. Not cheap but mix was perfect! As said ealier, the aluminum must be prepped perfect or all will be for not!
    iseau,
    Do you have a part number/paint code? I need to order some for my 466. Also, who did you contact at Midwest Industrial Coatings? Might make my ordering the paint go easier if I have the part number/paint code.
    Thanks,
    Gary
  3. Maybe Knot
    Maybe Knot Member
    Nashville Tn
    Barring the mfg suggestions for prep, an old painter's trick for painting aluminum is to first wash it in straight vinegar. Evidently the acid in the vinegar mildly etches the metal and causes the paint to stick.
