Click for Burger Click for Abeking Click for Burger Click for Delta Click for YF Listing Service
Hot water tank - Element problem!
Discussion in 'Technical Discussion' started by Mikeyessir, Dec 31, 2014.
  1. Capt J
    They usually use way too much electricity at once for a yacht. Also, they have issues of their own, especially with hard water. Stuck solenoids etc. Also need a constant water pressure for them to work correctly and you don't have that on a yacht unless you have a variable speed water pump, which most don't.
  2. NEO56
    NEO56 Member
    Miami
    Learn something new everyday...thanks J.
  3. Mikeyessir
    Mikeyessir New Member
    MED
    Hello,
    Still waiting for new elements. I have discontinued use of the chlorine for now, flushed all tanks and the fresh water system. Our water is softened and put through polywound and chemical/bacteria filters so won't be a problem for now.
    We cannot alter the setup of the hot water system because the boat is still under warranty + there is no need to once we find the cause of the fault.
    Talking to one engineer on the docks last week we talked about how there is only two people on the boat all winter and running two hot water tanks with 6 elements on constantly with hot chlorinated water would rapidly corrode the stainless.
    So once we receive the new elements I will run the thermostats at a lower temperature setting, one tank in operation at once (alternating every other week). With the discontinued use of the chlorine we can just wait and see what happens.
    I went onboard another boat the same as us with the same system and traced all their wiring so I know we are good in that area.
    The manufacturer of the elements are convinced we are boiling the tanks dry but I know this isn't the case because i've checked the vents are working properly etc.
  4. dennismc
    dennismc Senior Member
    Vancouver BC
    Do not operate the tanks at under 125 f as the chance of legionella exists at lower HW temps.
