Click for Ocean Alexander Click for Glendinning Click for Northern Lights Click for Walker Click for Ocean Alexander
Holding tank smell
Discussion in 'Carver Yacht' started by Garry Dawson, Sep 4, 2026.
  1. Garry Dawson
    Garry Dawson New Member
    UK
    Hi Guys
    I have a 1997 Carver 405MY in the UK. I have constant urine smell from around both holding tanks. I have cleaned and flushed the tanks with clean water a number of times and used various off the shelf tank cleaning products and replaced the stern tank hoses but can't get rid of the smell.
    We have only used the heads for urine, no solids over the last 14 years.
    Could the plastic tanks themselves be the problem?
    Any advise would be welcome.
    Old hoses.
  3. Garry Dawson
    UK
    Replaced all the stern tank hoses, didn't help.
    Those old Roto-cast plastic tanks are pretty good if supported well. Without support they can crack after lots of flexing on their own, like in a carver.
    Then, Roto-cast plastic tanks were built for a purpose, Cost-reduced (cheap).
    After all, 29 years from a Cost-reduced plastic tank is pretty good.
    Next ideas;
    Restricted vent lines.
    Splits in the tank where hose plastic hose barb screw in.
    Leaking macerating pump, fittings, valves and the tank cracked where this stuff screws into the bottom of the tank.
    Bad shower sumps (it can stink of pee also).
    Bad hoses forward.
    Ensure your bilge vents are clear.
    Get a big pump-up sprayer, fill it with cheap white vinegar, Spray everything in the bilges with it.
    Including under the deck plates.
    Around the head base also.
  5. Garry Dawson
    UK
    Absolutely brilliant, thank you Capt Ralf I will go through everything listed.
