Click for Ocean Alexander Click for Abeking Click for Burger Click for YF Listing Service Click for Delta
hi what is average hull thickness of 45ft yacht.
Discussion in 'General Yachting Discussion' started by P_Bear, Jan 11, 2014.
  1. bernd1972
    bernd1972 Senior Member
    Flensburg, Germany
    Well, Pascal, the spanish even managed to design a navy submarine that would not surface (too heavy to float) because someone messed up a comma...
    So let´s not waste our time discussing that minor difference of building 3 times longer than initially mentioned... :D
  2. olderboater
    I would suggest starting at 45 inches.
  3. bernd1972
    Flensburg, Germany
    Good suggestion. With that size he might also get away with somewhat lower hull thickness. ;)
  4. YachtForums
    Not a chance. This is far too entertaining!
  5. olderboater
    Hope you're ready to cover his yacht when it's finished. He's a genius so it will be worth headlines. Maybe he'll give you a projected date.
  6. Belle
    Belle Member
    Paradise
    You are an evil wicked man....
    Think I'll build a boat tomorrow. Maybe out of sand.
  7. Old Phart
    Old Phart Senior Member
    I dunno
  8. HTMO9
    HTMO9 Senior Member
    Ships built of sand
    There where a lot of ships, boats and even yachts built of sand. With a little addition of cement of course. Building vessels out of concrete was very common, when steel was a critical resource and it was a very cheap method of building ships.
    The material is called Ferrocement. Quite a few home built yachts (sailing and power) where launched, using this building technique.
  9. Old Phart
    I dunno
    And there are even more uses:
    Rogers Group, Inc. | Crushed Stone | Sand & Gravel | Asphalt Paving | Road Construction > Industry Resources > Rockology 101: Learning > Sand, It's Not Just For Beaches
    P.S.- Addition of cement is cheating. :D
  10. HTMO9
    HTMO9 Senior Member
    Then we are back to the roots :D.
  11. bernd1972
    Flensburg, Germany
    ...seems like that´s exactly what this thread is about. Now we´re right where this was meant to go. :D
  12. Kafue
    Kafue Senior Member
    Gold Coast Australia
    You guys chased the GENIUS away!
    We could have found out a lot more about P_Bear by now, for example, is he a 15 y.o stirring us all up or a wealthy inventor trying to make friends around the web :rolleyes:
    I once had a client who was a genuine genius in the computer game world and although he was eccentric in many ways and wanted unique inclusions in his home that I had never done before, he was also one of the most modest, generous and polite persons I have met. There was also a great language divide between us as he was Japanese, this made little difference. Within a few meetings he proved to have learnt as much about the engineering required for his home than the engineer we had employed.
    As one member said, if you are a genius, it will show quick enough, no need to sprout about it. He still remains one of the best clients I have worked with.
    I doubt very much this P_Bear was more than a bored kid.
  13. bernd1972
    Flensburg, Germany
    maybe he decided we´re not worth his brilliance and so he went on to enlighten our friends at BD.net instead...
  14. dsharp
    dsharp Senior Member
    lake jackson, tx
    "you piss yourself up" - I'm still curious about this. I hope he returns.
  15. olderboater
    Between that and suing us all. Not real sure what he thought he could sue us over though.
  16. Opcn
    Opcn Senior Member
  17. YachtForums
    This thread has been stripped of unnecessary remarks by a member who registered today. His membership has been removed.
  18. Captain Jan
    Captain Jan New Member
    Poland
    Perhaps find out the weight of the bare hull for the boat you require and extrapolating from there might be a good cheat method of working this out?
  19. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    Who has a glass bottom boat? Guessing we'd need a minimum of 3/4" of thickness, so it'll be easy to see the S.S. Genius on the bottom after its maiden voyage
