Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for Burger Click for Nordhavn
Help with college project
Discussion in 'General Yachting Discussion' started by Jabor, Aug 18, 2009.
  1. Marmot
    Then why on Earth would you say "I think it is rare to have 12 sleeping guests on a yacht, then it becomes a cruise ship..." ?
    So I said 50 instead of 43, makes no difference. A 6 stateroom boat sells before a 5, and 12 passengers is hardly rare. Sleeping 12 onboard doesn't make it a passenger ship. There is a reaon for that number that I thought a captain, yacht designer, and charter broker should have known about ... after all wasn't that statement supposed to be advising a budding young designer?
  2. AMG
    First, we are not discussing charter yachts. My personal experience is that yachts are rarely filled up with sleeping guests and my personal view is that 12 is too many, this is why I used this: ;) ...Sorry if you didn“t got it.
  3. 84far
    84far Senior Member
    Brisbane, AUS
    new problem,
    its come to my attention that i have to work out the - weight estimation/distribution, hydrostatics, stability curve, intact stability, damage stability.
    how much detail would a 'designer' go down to? i did this bar the intact stability and damage stability for a 42' cabin cruiser for work and new its construction and everthing that went in to it... and that was effort... a 66m superyacht! is there a program that will work this out, or at least half of this?
    lars, all good, i got the wink.
    far
  4. AMG
    You can never learn too much, but if you are talking of a 66 m yacht, it is far too much for one person to make all drawings and calculations.
    A Naval Architect is normally responsible for the hull and the performance, and the Designer is doing what you see above the waterline.
  5. 84far
    84far Senior Member
    Brisbane, AUS
    i totally agree, im pretty sure its just an estimate that there after, i will further the question. cause it just sounds to extreme. maybe Jabor can shed some light on the situation.
    also i was thinking of using Starfire lower deck layout? any pros and cons to this? or does someone know where i can find a layout of Predator? my hull is pretty similar to that.
    also when a boat gets booked for charter, are the guests likely to be from all the same family (blood relations) majority of the time? and how many crew would u need, Starfire has 12?
    far
  6. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    My son jumped into this feet first last year. He carried out extensive analysis and comparisons, yet came up with conflicting conclusions. He planned his time well, yet ran out of it. He trawled the worldwide databases for information, and trusted the wrong sources. He also put a lot of faith in my advice, he took some, ignored some and after an extremely intense and copious amount of work and healthy expectation, he didn't make the finalists. The standards are extremely high, and extremely subjective.
    My only advice (deliberately biased toward generality and individualism) would be to design the project from inside out, not the outside in, and to plan your time extremely well. Set yourself sign-off target dates for (examples only) concept / hull form / internal layout / exterior styling / presentation etc leaving yourself some margins on time. And finally, dont leave a cursory glance at whatever classification rules may apply to the last minute...I'd hate you to realise a rather blatant issue just as your final renderings are printing off.
  7. Jabor
    Jabor Member
    Southern California, USA
    Hey guys
    I'm sorry I've been absent from the thread I started, I'm back home on vacation now, so I barely check my e-mails and messages.
    84far, I think you might be worrying too much about certain things. Not that you shouldn't care or ignore them, but as a designer it's more important to work smart rather than hard. You should be estimating the most technical things based on whatever research you do (articles, comparisons with similar-sized boats and similar shaped hulls) and worrying about things like exterior design, proportions, and overall living experience. When you design a real yacht you will have a team of engineers calculating and working out all that stuff, so the judges on any contest won't really mind if your numbers aren't perfectly exact. I know it'd be good to get a realistic figure, but that's just too much to do
    About the whole discussion on the 12 people subject, I appreciate all the help you guys are giving us. Keep the new information coming!
    Thanks a lot guys, good luck far!
  8. NYCAP123
    Interesting perspective from someone starting out and hoping to prove their worth. I hope you are extremely tallented.
  9. Jabor
    Jabor Member
    Well, I come from a car design school and my instructors are actual working professionals, and this is pretty much how we get things done. There's no way you can get even close to figuring out a production-ready vehicle and its packaging in a class project, which is something that a team of 2000 people take 4 years to accomplish. But we do know about what goes on in the technical side and do a lot of research and learning to get as close to reality as possible, but we can't replace the job of the engineer. As far as class projects, the designer's job is to match form with function, considering the overall user experience, technical feasibility, problem solving and innovative solutions, merging all that into desirable forms, textures, colors etc.
    I know I'm starting out and still have A LOT to learn, but expecting a design student working on his own to do extremely technical calculations is not only unnecessary, but will also deviate the designer from his main focus. Designers should be fully aware of the technical implications of their projects, but to get the job done they need only to speak the same language as engineers, not pretend to be one and do their job...
    Thanks for pointing out, I probably didn't make myself clear enough and might have sounded like a fool to many of you...
    Cheers!
  10. Seafarer
    Seafarer Senior Member
    Hudson River
    Art Center?
  11. K1W1
    There are very few amongst the current crop who have any level of comprehension of the technical implications of some of the back of a napkin scribbles being turned into something that works more than it's broken down.
    Pretty colours and textures along with soft furnishings where the Owner can climb on top of his companion of choice do not keep the yacht running straight, on an even keel and cool in a hot climate- Do they?
    Yacht "designers" (the pretty, pretty brigade) as you see them are really stylists, the real nuts and bolts, functional design work is done by Naval Architects and Engineers.
  12. Jabor
    Jabor Member
    Yes! Very good place to learn design, and the cool thing is that they're not focusing just on car design anymore, they've been encouraging the students to design all kinds of transportation...
  13. Marmot
    My SO graduated from the Art Center about 10 years ago and her portfolio is anything but transportation, most of it is industrial design.
    And being a marine engineer she is also amused at the stylists' claims to vessel design.
    Nice point on the stick there K1W1 ...
  14. 84far
    84far Senior Member
    Brisbane, AUS
    YOUNG DESIGNER OF THE YEAR AWARD 2010
    Submission Requirements
    REQUIRED DOCUMENTS
    The following documents must be submitted on CDROM or DVD, in the allowed format (Adobe Acrobat). Failure to submit all the required documents or in other formats without the prior agreement of RINA may lead to disqualification of the entry.
    1. Main index
    The main index must list all the required documents submitted.
    2. Brief summary of entry (Max 1000 words)
    The summary should briefly describe the entry, including how it meets the design specifications and any special features.
    3. Technical/Design Data
    3.1 General details.
    3.2 Stability information (weight estimation/distribution, hydrostatics, stability curves, intact stability, damaged stability etc).
    3.3 Performance prediction, power requirements, sea-keeping.
    3.4 Technical drawings (GA, Decks lay out, hull form, principal systems).
    3.5 Rules & Regulation (Rules and regulations complied with)
    3.6 Images (Maximum 12 images)
    4. Team details - CVs of members of the design team.
    ADDITIONAL DOCUMENTS
    Additional documents, images etc may be submitted. These must be listed in a separate index and in the allowed formats.
  15. 84far
    84far Senior Member
    Brisbane, AUS
    hi,
    ive been emailing the Director, The Royal Institution of Naval Architects, ill keep names out. but this is what he sent me.
    and basically said, the more depth u go down to, the more your impress the judges.... thankyou HydroMaxPro, that should take care of most of -3.2 :D
    Jabor, im half way through making the scale model. profile, top, front, back views have been completed. trying to figure out the the G/A of the boat is getting little trickie.
    what i am worried about is the power plant. would love some help on motor selection. can u get any old MTU or CATERPILLAR etc, and throw on an electric motor? i hear there is a loss of power, but not much.
    far
  16. AMG
    Seems as they are aware that the designer can not do all of this alone...
  17. K1W1
    I wonder if they are asking for team member CV's to make sure there are no specialists lurking in the background giving out their own ideas and designs under the entrants name.
  18. Jabor
    Jabor Member
    Ok, now I really need help. I'm still working on the research for all the safety regulations and Ceribbean/Mediterranean operation stuff, but I have no what is all the "stability" information. How can I get this HydroMaxPro? Or is there a book to learn about that?
    84far, when you say you're working on the scale model, do you mean an actual physical model or a 3D model?
  19. NYCAP123
    Someone may be realizing that working smart IS working hard and that the detail you shortcut may be the one that gives the job or the award to someone else. I don't envy you guys or anyone learning their trade. There is just so much to learn and know these days. Good luck.
  20. K1W1
    If you can get a copy of Simple Ship Stability by Alfred Carver that would be a good place to start, failing that can I suggest becoming a naval architect first so that when you do get to design things that no one has seen or thought of before you may have some understanding of the effect on stability, sea keeping and structural integrity.
    It would certainly allow you to join an elite group of Stylists (Inferior Desecraters) who have an understanding of the practicality and limits of some things they are pushing.
