Click for YF Listing Service Click for Burger Click for Abeking Click for Walker Click for Cross
Heater Exchanger and CAC Corrosion on My TAMD63A-P Twins
Discussion in 'Engines' started by FIQ, Sep 29, 2026.
  1. FIQ
    FIQ Member
    Olympia, Wa
    Interesting maintenance issues.
    Recently while servicing my CACs and exchangers I noticed some corrosion on 3 of the aluminum casings. The spacer rings had cracked by the drip holes. The o ring seats were destroyed.
    I tried to have them repaired, but no one would touch it. I was told that because of the configuration of the casing, mounting on a milling machine was impossible.
    Try as I might, I absolutely could not locate replacements, new or used.
    I asked fellow boater for advice and was told to buy either Cats or Cumins! Umm, ok, that's not gonna work!
    I used a Dremel and ground all of the corrosion away. A welding shop built up the area. Using a flat file and my Dremel, I reconstructed the seat. I had a machine shop make 4 spacer rings and the only unbroken one was going to be a spare.
    The units are now working beautifully! WHEW! That was way too close for comfort!
    A word to the wise, Stay on top of those aluminum exchangers! As a side note, I would love to talk to the designers that thought that aluminum was the way to go!
    chassis likes this.
  2. chassis
    chassis New Member
    USA
    Good job! Where there is a will, there is a way. What year are the engines? How many hours?
  3. FIQ
    FIQ Member
    Olympia, Wa
    The twins were born in 1996 and have coming up on 1800 hours.
    chassis likes this.
