Click for CL Yachts Click for YF Listing Service Click for Westport Click for Delta Click for Abeking
Heat Exchanger Gaskets
Discussion in 'Ocean Yacht' started by Boomer, Dec 26, 2019.
  1. Capt J
    If it ain’t broke, don’t screw with it. Very easy to break 30 year old copper or bronze
  2. Boomer
    Boomer Senior Member
    Seminole
    Roger that...will carefully round out the d shaped tubes a little and use some RV gasket maker on the ends to make sure it doesn't leak
  3. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Did it leak before? If you are talking about the bronze square to round end fittings of the cast iron tank..etc...that is some heavy stuff..I'm amazed they are bent up. No need to crank them down that hard. And what Capt Ralph said, I never knew this but bronze won't bend back with out cracking or what ever. That would really stink.
    What Capt J said if it ain't broke don't blank with it! Well, my version .:D It's an Older boat, like ALL of mine past and present. Some things are not ment to made like new again. Just make sure it does not leak and move on, IMO.
  4. Boomer
    Seminole
    Capt ralph said they are copper...in sad shape also
  5. Boomer
    Seminole
    Almost back together..did a run yesterday with water to flush the system..started adding coolant today...ran out..back to napa
  6. Boomer
    Seminole
    Success!!!...boat ran great and temps where they should be! Thank you everyone for your input...another project completed for the YF crew
  7. Capt Ralph
    So, What to you contribute to have been your issue?
  8. Boomer
    Seminole
    My best guess would be the HE as they had garbage in them on the coolant side...that and all the mud in the tank...everything else looked ok...t stats were probably ok but why take a chance when you are doing everything else?
