Click for Burger Click for YF Listing Service Click for Westport Click for Glendinning Click for Burger
Golden Ray to be scrapped in place....
Discussion in 'General Yachting Discussion' started by Oscarvan, Oct 19, 2019.
  1. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Bet that's loud up close.....
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    You'd have to think this detail is being added to the Pilot's check list upon boarding...
  3. rtrafford
    Vero Beach
    When you really think about how the scene may have played out, felt, reacted...it sure would seem that the change in course was related more to physics as compared to human decision, and that the physical shift initiated the chain of events.......that then all summed up in a plausible explanation pointing to human decision making.
    The lack of proper ballasting would have left her prone to considerable instability to any outside forces, and then amplified by the turn. Oversteering a correction could even had amplified the roll.
  4. rtrafford
    Vero Beach
    But a lot safer than Sparky holding a plasma cutter....
  5. C team
    C team Senior Member
    Kent Island
    Very cool article Chesapeake 46!
  6. chesapeake46
    chesapeake46 Senior Member
    Great pictures there ! Don't buy any used cars in Ga. if they seem too good to be true !!
  7. Oscarvan
    Chesapeake Bay
    I don't think ANY of those cars can be "saved" by Earl Scheib.....
    It's amazing to see exactly how piled up and damaged they are. I can only imagine the forces on that ship when it tipped over.
  9. yr2030
    yr2030 Senior Member
    Iceland
    Look like tinker toys
  10. LM Viking
    LM Viking Member
    Michigan
    Still there when I was on St Simon Island on February 20th. Apparently they are having trouble with the cut that includes the engine room and have broken the chain more than once. They were disengaged from the wreck at that time for maintenance. BC009615-42A8-419D-9F37-EEEC6C5618D4.jpeg
  11. LM Viking
    LM Viking Member
    Michigan
  12. Seasmaster
    Seasmaster Senior Member
    USA
    Capt J, it isn't the engineer who's responsible for ballasting the vessel [usually], it is the chief mate or cargo mate. I know, because I sailed CM on these types of vessels for several years. However, if you look at the pictures of the cut sections, you'll see that most of the cars were on the upper decks - so cargo loading CERTAINLY is a factor too. Correct ballasting might of solved ALL of the problem. But it is entirely possible that even with all the ballast tanks full, the cargo loaded too high would result in an angle of lull.
  13. Seasmaster
    USA
    As one who sailed on that type of vessel for several years, and passed ships close-aboard in several ports, including Brunswick, I can assure you that almost all pilots are working "plan A", but have "plans b through d" in their head.
  14. NYCAP123
  15. Seasmaster
    USA
    I'll say it again, and again. Too many cars on the upper decks. . . and, obviously, insufficient ballast. I worked as Chief Mate on these kind of vessels for 5 years. . .
    Oscarvan likes this.
  16. Capt J
    I ran by this monstrosity about a week ago. I'd say that 2/3 of the ship is gone and only the midship section remains.
  17. Capt Ralph
    3 of 8 sections are gone. They start back on cutting thru the ER next.
    I wonder if they are cutting thru the engine causing the issues back there.
  18. LM Viking
    LM Viking Member
    Michigan
    You would think they would plan to avoid that but I read somewhere they had broken the chain 3 times on that cut before they disengaged for maintenance when I was there on February 20th. They then decided to go up front and take out section 2 just behind the bow section.
  19. Capt Ralph
    Not sure the chain is working at all like they were planning.
    They are cutting lines of 6" holes in the hull sides to help keep the chain close to where they want the cut (rip). Even then the chain is still wondering.
    At best the chain is ripping, not cutting.
    I would of thought, in all the time it took to start working on this wreck, somebody would have welded some carbide teeth on the chain before it's use.
