Click for Abeking Click for Ocean Alexander Click for Burger Click for YF Listing Service Click for Glendinning
Going to look at a 1981 Viking 46’ Sportfish with DD8V-71TI
Discussion in 'Viking Yacht' started by Tank, Jul 24, 2020.
  1. PFalkner
    PFalkner New Member
    connecticut
    Thanks for that link I looked at that website and saw that they were pins but completely missed that they were nylon I must be losing my mind
  2. PFalkner
    PFalkner New Member
    connecticut
    The specs say for engine serial # n90 with a no load speed of 2500 rpm . I think with the bigger injectors they had a lower rpm
    No load RPM is always higher than loaded rpm. I'm pretty sure your engines are supposed to make 2350 rpms with a load WOT. They're very good running engines with N90 injectors. Crisp, clean, good throttle response. I ran a set of Covingtons that initially had 110's and the owner had 90's put in during the rebuild.
    Friction. Just drive it out with a punch and mallet.
  5. Capt Ralph
    Covington, S&S, J&T and others were all called on for some more HP than DD delivered.
    If painted green; should be N90s.
    Not Green; could have anything for injectors, turbos, blower ratio or cam timing.
  6. PFalkner
    PFalkner New Member
    connecticut
    they are green
  7. Capt Ralph
    Then there ya go, N90 for sure.
    Nothing exotic. Just a solid & stock DDC engine.
    It does not get any better. :):)
  8. Boomer
    Boomer Senior Member
    Seminole
    Ocean yachts will give you close to that cruise with 671ti twins
  9. Capt Ralph
    I think Oceans are a heck of a bit lighter also.
