Click for Burger Click for Cross Click for Westport Click for JetForums Click for YF Listing Service
Generator slip rings
Discussion in 'Generators' started by timvail, May 27, 2015.
  1. timvail
    timvail Senior Member
    georgian bay penetanguishene
    while correcting a hard starting problem on a 1980 6.5 onan gen set, i noticed some red rust ion the cooling blade along with a different ping sound when running. further investigation revealed the slip rings are loose, appears all 4 of them. Not sure if this is causeing the strange noise, but suspect these rings should be tight. If so how do i tighten them?
  2. K1W1
    Buy a new genset
  3. timvail
    First, the gen set only has 1000hrs on it. It runs just fine and carries a load no problem. As per my original question, can the slip rings be tightened?
