Click for Westport Click for Cross Click for Walker Click for CL Yachts 99X Click for YF Listing Service
Fuel System Woes Revisited
Discussion in 'Post Yacht' started by Post Mayhem, Jun 23, 2015.
  1. K1W1
    Now I understand why you said you have multiple return lines, the one you want to put the flo meter in is the one that goes back to the tank not the ins that go tot the banjo connection on the fuel filter which if my memory serves me correctly would have been a CAV 7111-296 or a pair of them when those engines were in automotive applications.
  2. bobhorn
    bobhorn Member
    Kemah, TX
    Actually all three return to the tank so you have to combine them and then go through the flow meter. Probably an installation issue when the boat was built. Emailed Bob Smith at American Diesel, he was involved in the Lehman conversion, and I think he responded that the return from the head was extremely small and could probably be ignored. But I decided to combine all three since I was in there anyway.
    The biggest issue I have with the Floscan is the pulsation dampers ahead of each flow meter. The flow meters themselves are very small but the pulsation dampers are about the size of an automotive oil filter. Had not anticipated that when I ordered them.
  3. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    Found the data plates and you were very close! 220 fwd and 280 aft. Thanks!
