Click for Burger Click for Ocean Alexander Click for Northern Lights Click for Delta Click for Walker
Fuel system on a Post 56
Discussion in 'Post Yacht' started by Dennis serras, Jan 22, 2015.
  1. Beau
    Beau Senior Member
    Beaufort, NC
    Dennis
    My 50 gives me the option to transfer fuel from either fore or aft tank. It will be apparent from the helm labeling if yours does as well. I believe Posts tradition is/was to valve only one engine, so don't go crazy looking for valves that control the Star engine fuel supply. But do have somebody come on board to go thru ALL your systems with you. We folks are at a disadvantage "looking" from here.
  2. Beau
    Beau Senior Member
    Beaufort, NC
    VCapt J
    With due respect, what you are describing is for senior operators. Dennis is new to this boat and having a challenge with the ordinary set up. TMI in my opinion ... too much snow here in NY, so I'm overusing this forum to keep busy.
  3. olderboater
    Dennis
    There have been a couple of suggestions made that you haven't responded to (or I've overlooked the responses) regarding getting assistance from a surveyor or and experienced captain when you get home to take you through your entire boat and all its systems.
    I guess rather than us continuing to suggest that I'd ask the question now as to whether that's something you're considering, going to do, or are rejecting that advice. Either way I'm sure some will continue to try to assist you from here.
    Dennis, where do you keep the boat? Is it in Naples? or on the East Coast? A good Captain might be a little better than a surveyor as a good Captain would also know how things work when using the boat/in operation (real world experience on trips and such) over a surveyor. But there are a lot of Captains that wouldn't know anymore than you do.
    What is your boating experience prior to this boat? Are you using a Captain now to help you run it?
    It is a bit advanced, but I disclosed to make sure not to pump it overboard, but it could also really save him if the transfer pump went down at sea and one tank was running low.
  6. Dennis serras
    Dennis serras New Member
    Naples fl
    Hi guys,
    Got in a couple hours ago from Key West to Naples where I keep my boat. Got my butt kicked for first two hours. Waves breaking over to of boat. Stuffed the bow once. Anyways, transferred fuel when I got closer to Naples. I think Beau is right in saying it drains back with valves left open. I have a buddy who run a 62' v
    Viking. He's like Mackguever. I'll work with him on fuel. I ran off the forward tank and transferred from aft tank. I'll keep you posted as to how fuel system works
    Dennis
  7. Dennis serras
    Naples fl
    Beau,
    From the helm you can transfer fuel from aft to forward or forward to aft. I talked with Patrick who has something to do with Post now being built in Virginia ( haven't had an orders yet). He was going to contact the old CEO of Post, which he says knows everything about my boat and have him contact me. Hasn't yet. I have to follow up. Patrick says I have the last Post 56' made. Boat great. Fast, seaworthy, comfortable and burns lots of fuel
    Dennis
  8. Beau
    Beau Senior Member
    Beaufort, NC
    Dennis
    We all wish you many years of enjoyment with your new vessel. IMO, the "new" Post has not be very helpful to existing owners, hope they prove me wrong. Do get someone to help familiarize you with a very complicated bit a machinery.
  9. olderboater
    What were conditions? I'm just curious because what you're describing sounds much rougher than they were later. Last I saw was 2-4'.
  10. Dennis serras
    Naples fl
    Close to Keys were 5-7 I'd say. As you got closer to Naples, sea laid down to 2-4. Interesting though, know one out in the gulf . Guess to rough for smaller craft
  11. Dennis serras
    Naples fl
    Hi guys,
    Finding out alittle more bout fuel system. I transferred fuel from aft tank to forward. That's what transfer switch said at helm. Guess what! Top fuel gauge not fwd tank but aft. Sooooo when I transferred fuel I was transferring from forward to aft. Waiting for old CEOto call. Sent pictures to him of everything. There isn't a manual for a 56' Post. Old CEO supposed to know a lot. Patrick, who bought or runs Post now found hand wrighten drawins which he is going to send. Aft tank is 650 gal. Fwd tanks (1) 350 gal and (2) 92 gal.
  12. Kafue
    Kafue Senior Member
    Gold Coast Australia
    Hi Dennis,
    Congratulations on the new boat.
    Been following this thread with interest.
    Although I don't have a Post, my boat's fuel system was done by the guys at Merritt and there was little information on how the system should be operated when I first used it, so I can relate to your current situation. Also, my boat had been sitting for a while when I bought her, so the fuel was not the best quality.
    Something that maybe worth mentioning.
    With all the fuel transferring that you are doing, might be an idea to check your fuel filters. If the boat was on the market for a while it likely has built up some growth in the tanks. Add the fact that you have been out in rough seas and a lot of this growth would be floating around the tanks, then drawn into the fuel lines and filters. Hope you are running at least 2 Racors or similar per engine. It can be a real pain when you lose an engine while out in rough water and have to change a filter.
  13. Dennis serras
    Naples fl
    Thanks Kafue,
    When I brought boat back in October, I was transfering fuel all the way down trying to figure out how fuel system worked. I was putting 500-600 gal. Of fuel a day splitting it between tanks. Think I'm in good shape
  14. P46-Curaçao
    P46-Curaçao Senior Member
    One of the first times I wanted to go out with my new (to me) 46 Post, the port engine fired up, but stalled within 2-3 seconds… Boat was loaded with friends, food and drinks, so you understand, that was no fun! :(
    But that morning I learned my fuel system, because it was the only thing I could think of that time, as source of the problem. I followed every fuel line, labeled it with ‘blue tape’ and a permanent marker, and checked fuel flow.
    Finally I couldn’t find the problem, everything seems to be OK, so decided to call my (US) mechanic, he heard my story and told me, it was most likely, somebody touched the emergency shut off at the flybridge, which was the case!! :)
    That day I learned two lessons, tell everybody, to never touch anything on the dash panel, and I discovered my complete fuel system incl. fuel transfer (and prime) pump configuration…
    Bleu tape is still there, I need to make some time to print some fancy Dymo labels :cool:
  15. Beau
    Beau Senior Member
    Beaufort, NC
    Dennis
    You have received good advice here. Can't you afford to change racors?? I hope you don't hurt anyone with your.... I'm done. I'm beginning to think this is a bogus thread.
  16. Beau
    Beau Senior Member
    Beaufort, NC
    Answering a recent email to me:
    Here's my response to your email, because I think my response should be public. I think this owner may be dangerous. I travel with my family in the block Island sound et al. Is an owner like he going to be running at me in the fog (or some one in the keys) at 25 knots with his fingers diddling on the radar, if he even knows where that is? I'm normally not emotional, but Dennis worries me. I cannot in good conscience encourage him to pilot his 35 ton missile. Carl, I hope I have stepped over any edge here.
  17. Dennis serras
    Naples fl
    Beau,
    Not sure I understand. Bogus thread??
  18. Beau
    Beau Senior Member
    Beaufort, NC
    Dennis
    Please be candid with us, what is your boating experience? I'm snowed in, so I am too focused.
  19. Dennis serras
    Naples fl
    Beau,
    I have a lot of boating experience. This my first big boat. I have over 100 hrs in the Post. Most of done with the Captain who ran this boat with previous owner. I have gotten my Captains license for my own personal knowledge Called a 6 pack for those who haven't done.
  20. Dennis serras
    Naples fl
    I'm not a foolish person. I have flown my own pressurized twin and have over 1000hrs in the air. My ability to navigate and understand radar is most likely better than most. I don't think I have been anything but candid. To the question can I afford Racor ,I have 2 on each engine and all have been changed. My pre-check for my boat is like it was for my planes. I check everything before I run
    Thank you
    Dennis
