Click for Northern Lights Click for Glendinning Click for Burger Click for YF Listing Service Click for CL Yachts 99X
Expansion Tank Coolant Pressure alarm
Discussion in 'Cabo Yacht' started by CSkipR, Feb 2, 2014.
  1. Voodoo
    Voodoo New Member
    Tennessee Knoxville
    Where is the water pressure expansion tank sensor located
  2. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    If the gauge is showing nothing (not even zero) then more than likely it’s the sensor. I had that happen twice. Before replacing sensor check the connection at the sensor as it could have a loose wire inside the square cap.
    If you happened to open the cap when the engine is warm it will lose that pressure. Then u need to pump up with air. If u let it sit overnight and start it up then it will build pressure as normal.
  3. Voodoo
    Voodoo New Member
    Tennessee Knoxville
    Do you have a picture of the sensor
  4. Voodoo
    Voodoo New Member
    Tennessee Knoxville
    I have a coolant pressure water pump aft fault any thoughts
  5. CaboFly
    CaboFly Active Member
    Seattle
    Skip sold his Xabo so not sure if he is still following the forums.
    Most likely the sensor.
