Click for Mulder Click for Northern Lights Click for Delta Click for YF Listing Service Click for Abeking
Engine stuck in reverse
Discussion in 'Technical Discussion' started by Brian G, Jun 28, 2021.
  1. Brian G
    Brian G Member
    Destin, FL
    I have a CAT 3412e engine with a Morse KE4 controller. While backing up, the STB engine got stuck in reverse. Moving the throttle to the forward position and giving it some fuel just made the boat go faster in reverse. The engine will still start but immediately goes into reverse without touching the throttle. The port engine still works fine.
    Is the main issue with the helm station, the engine, or the ZF transmission? Thanks in advance for any suggestions or guidance.
  2. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Can't be the engine, it does nothing related to reverse. It has to be the control or the ZF Trans. Almost certainly the controls or shift servo in your trans. What have you done to try to isolate and figure it out? Do you get any warning lights on your controls? When you say Morse KE4, is this cable controlled? Maybe just a busted cable or cable came loose at trans?
  3. mapism
    mapism Senior Member
    Sardinia
    I believe they are actually electronic controls from Teleflex Marine.
    Of which BTW I must have the installation/operating instructions, if that might be of any interest to the OP.
    But as with any electronic control, I think he will have to involve a specific technician anyway.
    The only easy check, if the gearboxes are actually controlled through cable actuators in the e/room, is whether the lever on the gearbox is moved either side of neutral upon helm lever movement.
    If yes, the problem is with the gearbox, and there's nothing wrong with the control lever.
    If no (which I think is more likely), some electronic components - which could be either the lever or the e/r blackbox - is faulty.
    PS: I agree that the engine can't be the culprit, anyway.
  4. bayoubud
    bayoubud Senior Member
    Florida
    Check the shifter connection on the gear. Had one come loose and fall off locked in fwd years ago.
  5. Brian G
    Brian G Member
    Destin, FL
    Thanks for the help! The cable from the actuator to the transmission was broken at the gear shifter/lever. I really appreciate it!
  6. Pascal
    Yep... had a similar issue years ago with the same controls/engines/gear. There is a cable between the Morse servo and the lever on the gear. That cable can fail or bind. In my case it wasn’t broken but had been moved by a mechanic. The Morse servo sensed an a normal load, idled the engine and returned the gear to N. It happened a few times over a period of time and took me a while to figure it out.
    Brian G likes this.
    Change both cables.
  8. Brian G
    Brian G Member
    Destin, FL
    That's a good reminder. Will do. Thanks.
