Click for Cross Click for Burger Click for Delta Click for Glendinning Click for YF Listing Service
Engine shutdown but now fault MTU v10 Serie 2000
Discussion in 'Engines' started by Claus, Jul 28, 2020.
  1. Capt Ralph
    Depends on how it is installed. Does the port engine need a separate signal to shut down? Is this signal a N-O or N-C loop or a real data (CAN-Bus) command?
    I can easily imagine a normal closed loop per engine from the suppression control box.
    I would hope the ECM would record this event. Per post #16, no data captured.
    I have to admit, I am not MTU savvy. But the predecessor, DDEC I am,, some.
    DDEC never captured power failures.
    Sometimes when they fail, they'll only shut one engine down........
  3. TOM TADSEN
    TOM TADSEN New Member
    Only the port engine shuts down, it has happened at idle while preparing to leave the dock and more
    often at my cruise 1800 cruise rpm. Normally the screen goes blank when the engine shuts down.
    once the screen went blank and the engine kept running. Very very strange. No codes saved to
    diagnose the issue. MTU out 5 times now.
  4. Pascal
    If the screen goes black then it’s not fire suppression
    on ours, the helm displays have no impact on the engine. I had a display fail last month and engine would start and run just fine. No big deal since all the critical data is displayed on the Isis system anyway.
    If you have already bypassed the key, I would check the wiring between the key and box, ours are up under the helm
  5. Capt Ralph
    That's bad power to the box.
    You won't capture any codes.
    Damaged wire or connect.
    Bad breaker.
    Bad switch.
    Loose fuse.
    For hit and giggles, swap panels port to stb, just in case a panel is crow-baring a ECM over.
  6. Fiammetta42
    Fiammetta42 Member
    Liguria Italy ( boat )
    Bad ECU .
    Try swopping over to get the diagnosis confirmed or eliminated
  7. Onedrew1
    Onedrew1 New Member
    Annapolis, MD, United States
    Found this thread looking for solutions to what started as a similar problem on MTU 2000 10V. Ours was shutting down for no apparent reason, would restart (the first couple times). Strange codes not ecu codes. Had mechanic in after first shutdown, found all ok. No reason for shutdown found. When it shutdown the last time, we also lost the gear oil pressure display and showed a negative ground fault on the boat's DC panel. Ended up finding chafed wires/ shorts within the "bayonet coupling" (big metal box which is junction to gear sensors etc).
  8. Capt Ralph
    Welcome to YF.
    Glad you did find something and thank you for sharing.
  9. Capt Ralph
    I wish the previous posters would update us on their findings and fixes.
    chesapeake46 and motoryachtlover like this.
  10. scott trommer
    scott trommer New Member
    AZ
    Wow! Just experienced the same issue on my port MTU V10-2000 r93. Three times at 10-15 minute intervals, engine went to idle, screen blanked and reset. Like key was turned off and right back on. Engine remained running. After screen reset, engaged clutch and set rpm. After the third “reset”, engine ran ops normal for 2 hours until docked. Appears issue needs to remain for >10 seconds to code. So, no code as it’s momentary. Never happened before, connections all look fine. Scheduled for a tech, but not optimistic. Thinking ECU going south. If after tech review, if it happens again, I will have ECUs swapped to rule in or rule out ECU issue. Please report any findings! Thanks!!
    Scott
