Click for CL Yachts Click for Walker Click for Burger Click for YF Listing Service Click for CL Yachts 99X
Engine Room Air Conditioning?
Discussion in 'General Yachting Discussion' started by PremierPOWER, Dec 25, 2020.
  1. Capt J
    You don't want just 1 chiller, you really should have 2. If you have an issue with a chiller, the entire boat doesn't have A/C, chillers take a while to get a new one to replace a bad one, other issue is the entire boat has A/C or HEAT at the same time.
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Good points!
  3. Pascal
    That’s the beauty of chillers; redundancy. If you loose one, the boat is still usable although a little warmer on a summer afternoon... lose the salon condenser in a modern boat and it s game over. Or the master condenser.
    mom a small boats, it’s actually easier to convert because the hose runs are much shorter
    capt J, keyword: Cruisair/Dometic. Lousy customer service. Couple of years ago We lost one of the Cruisair Chillers on the boat I run and indeed it was 6 to 8 weeks for a new one. Talked to my AC tech and they rebuilt it in a week for half the price of a new one. But again at least the boat is usable. As I said, at night even in summer I rarely run both chillers
  4. amgscrap
    amgscrap Member
    boca raton
    Pascal
    I have a Lazzara LSX 64 with two chillers. Each one alternates on and off between cycles unless the demand calls for both. If I lose one I do have the other which can do the whole boat even in summer. Are yours the same or do you manually select which chiller to run?
    In your situation, I would just run 1 chiller and leave the other off. You're better off having 1 run longer times on before cycling off, then everytime you clean the A/C strainer swap to the other one.
    As for chillers. I just am not seeing the life out of them. Had to swap out both chillers in a 2013 yacht 2 years ago because they were both bad. Now having to swap out 1 chiller with 4 compressors in a 2011 yacht because the fresh water weld on the chiller is bad and leaking a lot and not worth fixing.
    On a smaller yacht, like let's say the 66' Sunseeker I managed, it has 4 salon compact units, if 1 goes bad, big deal you'd hardly miss it. Also not the huge electric load when 1 chiller comes on and is running when the boat is idle. It also has 2 a/c sea water pumps along with seperate raw water pick ups and strainers. Each stateroom can select either heat or A/C whenever they want. Chillers make a lot of sense in 75' and over. Under that, I've never managed a yacht with them that didn't lose chilled water monthly, didn't have a hose sweating somewhere, or some other issue.
  6. amgscrap
    amgscrap Member
    boca raton
    Pascal
    I have the original chillers for over 6 years when boat was built. Luckily I don’t lose chilled water or sweat. I have found that most boat builders undersize their units for the Florida market. I had a Sunseeker with the Sahara package A/C and when in the Bahamas in the Summer it was not great. When I had the Lazzara built I oversized the units and added more air handlers in the salon which is a glass palace and needs it.
  7. Pascal
    I m not seeing long life from remote condenser either. On my own 53, with 5 condensers I was replacing one compressor every couple of years so on average they d last 6 to 8 years.
    i was running a 70 footer with 6 or 7 remotes and same thing... replacing one compressor every 12 to 15 months. In the 8 years I ran it we replaced the big salon condenser twice!
    I ll see how long my Flagship chillers last on my 53. They’re only 4 years old now.
  8. amgscrap
    amgscrap Member
    boca raton
    Since my chillers are a little over six years old you are scaring me of a future large expense. Although I think the new chillers are no longer copper but titanium which should have a much longer life.
  9. Capt J
    I'm seeing around 8 years on the package units. One is going on 13 years (out of 6 units on 1 boat). The package units are so easy to change out though, so aside from the price of the unit, the exchange is quick and easy. Few mounting bolts, couple of wires, and 2 raw water hoses. The new ones R410 are monsters compared to the old R 22's, twice the fan CFM and temps coming out of the same vents are 32-34F versus 44-46F with the old R22 ones.
  10. bayoubud
    bayoubud Senior Member
    Florida
    Our chillers crashed at 6 years, they were cupronickel and raw water side was likely aggressively cleaned before we purchased. The inter pipes pin holed and dump the Freon. Titanium out performs Cu-Ni in salt water and much more resistant to corrosive de-scalers. I like the chillers over standard compressor units , especially when you get to 5 or more air handlers.
  11. rtrafford
    rtrafford Senior Member
    Vero Beach
    Agreed. My controls for the two units are staggered, so the second only gets called when the load is heavy. The modern screw compressors also spin up, so there is no traditional load spike at start. I let #1 carry the majority of the load, and periodically I shut it down and exercise #2 for a while. Same with the redundant cooling water pumps. Alternate them with strainer sessions.
  12. amgscrap
    amgscrap Member
    boca raton
    Mine automatically alternate. When chiller one reaches its temperature and shuts down then next cycle chiller two will run. When both chillers run at same time when reach temperature one will shut off and begin alternating cycle. Thus I have nearly same hours on both chillers
  13. rtrafford
    Vero Beach
    Same thought process has had me spinning over adding a small first stage unit that is somewhat sacrificial. I've spoken with a company building 24k BTU 24v DC units, thinking that's a terrific use of both DC as well as adding longevity to my "big" chillers.
  14. bayoubud
    Florida
    We had one boat with ac in the er. The salon air handler was in a built in sofa with a drop going thru the floor directly into the er, You could turn air on/off in the er. It was great to have in the summer while doing maintenance.
  15. rtrafford
    Vero Beach
    You'd want a smoke, fume and fire plate on the ER side of such a duct lest anyone get the idea of just running a duct to their ER via a Y duct valve or worse.
  16. bayoubud
    Florida
    Not sure if it was original install, it was a simple supply duct with a plastic cover that would open and close on the er ceiling. Good point, a friend of mine still owns the boat, I will make him aware of that. Thanks for the suggestion.
