Click for Abeking Click for Westport Click for CL Yachts Click for Nordhavn Click for Walker
Engine Controls
Discussion in 'Technical Discussion' started by SplashFl, Sep 27, 2025.
  1. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    Not yet checked my fish scale against a known accurate scale but just checked the throttles & gears on the bridge and will speak with the mechanic working on them on his next visit. Port gear control was about 7 lbs. Starboard gear awaiting a parts delivery. Port throttle 6 lbs. & Starboard throttle 10 lbs. with the scales hook grabbing just below the round handle balls. If mechanic can get them all down to 6 I'll stick with the hydraulic for now.
    Still fresh in mind were electronic cable conversion controls once installed on previous Bert but 3 of the 4 were wiped out when lightning hit a boat a couple homes to my west. Don't recall the brand but upon return the company sent a full refund.
  2. mapism
    mapism Senior Member
    Sardinia
    I take your word on SFs, because in my neck of the woods there aren't many around.
    But I did come across several Kobelt controls in fast MYs (both OEM installed and retrofitted), obviously also in the f/b, hence much more exposed to weather than in the main helm.
    Some of them were 20+ years old, and the worst I've seen happening to them is that the control head at the base of the levers loses its shine and looks worn out, in the chromed version (as opposed to the more durable black version).
    BTW, Kobelt controls can also be interfaced with their own wired remote, which is somewhat ugly but very solid, and allows full control of everything: gear/throttle/rudder/thruster.
    Which for all intent and purpose, can also replace a fixed third station.
  3. mapism
    Sardinia
    At risk of stating the obvious, another thing to consider is that with electronic controls you lose the separate levers for gear and throttle.
    Which many folks hate, but most of those used to them (myself included) prefer them to single levers every day of the week and twice on Sunday!
  4. rtrafford
    rtrafford Senior Member
    Vero Beach
    I obviously went with single lever side controls for the PB helm setup. But I do recall that I could have gone with independent throttles and gears, say had I set up a second station aboard. The flexibility was available with Kobelt.
  5. rtrafford
    Vero Beach
    edit: In looking quickly at their web product guide it doesn't;'t appear that they offer separate throttle and gear units today. Perhaps that's a bad memory or a change in their line.
  6. mapism
    Sardinia
    I can neither confirm nor deny what you remember, but my (possibly outdated by now!) understanding is that the only producers of electronic controls with separate levers used to be Livorsi and FB Design of Buzzi fame.
    Unsurprisingly, because for "normal" boats like those we are debating, single vs. separate levers is essentially a matter of preference.
    But with ultra-fast boat meant to withstand wave jumping, separate levers are an absolute must.
  7. rtrafford
    Vero Beach
    My vessels are absolutely the antithesis of wave jumpers. Even the SF was designed for 10 footers more than it was for Bimini starts...
    Single levers are much easier and free up your hand for bow thruster controls or other measures like steering in tight spaces. Seperate levers for race boats are one thing, but everything else the single levers are much easier, also keep certain people from shifting with the throttles up and damaging gears and running gear.
    Cabinboy likes this.
  9. Pascal
    Whatever happened to the old Morse KE5s? I had them on a 70 with 3412Es and they were pretty good.
  10. mapism
    Sardinia
    I never, ever had to use the throttle levers while maneuvering, because engaging/disengaging gear is more than enough, unless you like to dock Chesapeake cowboys' style.
    Which means that the only handling difference is that with separate levers you don't need to worry about accidentally accelerating when engaging gear.
    I can't recall if this is also true of the Hynautic system which is being discussed, but just as an example, mechanical cable levers like these incorporate a safety lock that don't allow you to do that.
    All that said, what part of my previous statement "single vs. separate levers is essentially a matter of preference" you didn't understand?
  11. rtrafford
    Vero Beach
    I liked them because when maneuvering the extra thrust was always already in hand. There was no secondary shift of hands. Steer with the props and thrust.
    I've been in current situations at idle with the big girl whereby the 700 RPM shifting provided little in terms of controlling the boat. I needed 770-780 RPM to get response and ended up shifting at that RPM to control the situation. Not ideal.
  12. Pascal
    Re. Use of throttles.
    It depends on the boat and the size of the engines. Trawlers or underpowered boats will need additional RPMs when maneuvering. Planning hulls with larger engines usually don’t but sometimes bumping to 1000 can come in handy. Same with rudders, I know many advocate not using rudders but it can help as well.
  13. rtrafford
    Vero Beach
    Agreed on rudders. My standard maneuver is to center the fins and rudders on approach. The rest of the move is via gears and thruster. Of course conditions can modify that standard. She responds well, and she's heavy, so she reacts better with an additional 75 RPM. So I'd share that the additional RPM is my second standard. Increase from 675 to 750-780 and approach with more confidence with some wind or tide.
  14. mapism
    Sardinia
    All agreed.
    When I previously said I never touch the throttles while maneuvering, I was referring to my current planning boat, which makes 6+ kts at idle and reacts to gear engagement alone even more than I'd like.
    In fact, coming from a trawler that I owned for 17 years, it took me a while to get used to her.
    OTOH, also with the trawler I rarely used the throttle levers when docking: I only had to with crosswind, also because she had no b/t.
    But other than that, it was mostly a matter of keeping the gear(s) engaged for much longer than with planning boats.
    By and large, with the trawler I had one or both gear engaged for about 80% of the total time it takes to dock, while with my current boat it's the other way round: after a brief gear engagement, the boat gains enough inertia to move fast enough in neutral, requiring only a final gear touch to stop her.
    I'm referring to mooring stern to dock BTW, which is what almost every marina requires, in the Med. But the principle still stands.
  15. SplashFl
    It's my understanding the Glendinning control heads are nearly completely waterproof; not so for ZF Controls. Their also now making them in a single handle design. Why are you "worried" about Glendinning ?
  16. SplashFl
    Evidently Pannish Controls use cables. Cables, IMO, are good for up to two stations and I have three. Previous Bert also had three but when hooking up the controls on the tower it ruined them all. The mechanic working on my Hynautic said the more stations the stiffer each will be and the only answer is electric.
