Click for CL Yachts 99X Click for Nordhavn Click for Walker Click for Ocean Alexander Click for YF Listing Service
Dry bilge Solutions
Discussion in 'General Yachting Discussion' started by Danvilletim, Aug 5, 2021.
  1. mapism
    mapism Senior Member
    Sardinia
    Because S/skr is indeed a premium builder in some ways, but attention to detail in "behind the scenes" installations just ain't one of them.
    It's a boat, floating in water. I see more issues with bilge pumps in "dry bilge" boats because they just sit there and don't get exercised. Things may drain into the bilge, sometimes it's the engine room hatch, etc. etc.
  3. mapism
    Sardinia
    That's precisely what I meant with my previous comment ref. attention to detail (lack of) in some "hidden" parts of the boat.
    See, it is indeed possible to build e/r hatches that don't let one drop of water inside, no matter how hard you could try, even with a pressure washer.
    As well as it's possible to build e/r air intakes which drain 100% of external water outside - be it when washing the boat, or when it rains, or in rough seas.
    And it's not hard to fit a shower pump box wherever there is some condensation water to be collected (fridges, chillers, whatever).
    In this respect, what you said ("there's nothing wrong with that") is a bit debatable.
    Sure, we aren't talking of something that could sink a boat, but I can name you several boats of other builders whose bilges are normally as dry as a bone, mine included.
    Which is something I very much like, not because I'm maniac about it, but because if and when you see some liquid, you know there's some fault to be found somewhere.
    That said, I agree that bilge pumps should be regularly exercised.
    But I very much prefer to do it myself, rather than let some unidentified liquid do the job, if you see what I mean... :)
  4. rtrafford
    rtrafford Senior Member
    Vero Beach
    Yes, we're using them. We change them every couple of years to avoid buildup and failures. But other locations like a forward bilge and laz, where we want zero water needs a different solution.
    LM Viking likes this.
  5. rtrafford
    Vero Beach
    We have an aft and forward sump in the "wet" bilge so that water sits only in the low sump, not in a wider, open area. Sumps can then be cleaned and maintained regularly. Any damage being created to a metal boat is then relegated to those sumps and can be better monitored very long term.
  6. Ric
    Ric New Member
    South Carolina
  7. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
  8. Capt Ralph
    Into a shower or AC sump.
    Just another mini/multi diaphragm pump albeit a cell phone i/o.
  9. rtrafford
    Vero Beach
    Bilge pumps leave a reside of water in the bilges. They can never pull 100% of the water out. If maintaining a dry bilge is important to you, Arid is the way to go. I have a 10 port system aboard, and I pull from every bilge as well as the grey water tank. An aluminum hull wants me to keep the bilges dry, so I oblige.
  10. rtrafford
    Vero Beach
    Yes, I routed into a galley sink overboard discharge.
  11. PPD
    PPD Member
    CT
    Pascal - I like this solution. It is Redneck, but for the money spent, the simplicity of the system, I don't think you could beat it. I shop vac the fwd bilge in the 40 footer every couple weeks. It's the best way to get it all out. Shop Vacs are cheap, and they work.
  12. Capt Ralph
    I luv the cheap vacs that use a 5 gal pail.
    Toss it when dies and order another one on sale (<$20) and fry another one.
  13. Pascal
    bucket head
  14. Capt Ralph
    I resemble that remark :(.
    Thank you brother.
  15. rtrafford
    Vero Beach
    Curious if you could purchase the pick up pucks from Arid, tie them to your bucket head via a manifold...
  16. Capt Ralph
    Never thought about that. I do like the thought.
    I guess you would need a low pressure spec of the usual pump and compare it to a lil shop vac.
    It would be worth an experiment.
    If it does work,
    Leave the vac in place and put a 30 minute timer on it. Crank the timer over and walk (crawl) aweigh.
  17. rtrafford
    Vero Beach
    Build a manifold with a simple ball valve on the opposite end of the suction, use it to vent the suction relief as needed. Once set, it's set.
    Tell the company you need to buy replacement pickups and tubing.
    BlueNomad likes this.
  18. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    FWIW you can buy the Bilge-B-Dry pickups on their website, 2 for $30. https://www.neptunianskyllc.com/product-page/bilge-water-stone-pick-up
    Anyone look into what manifold/fittings would work? Kind of liking this solution. Keeps it simple.
  19. rtrafford
    Vero Beach
    You need the pickups and the tubing that properly fits those pickups. Building the manifold would simply allow a piece of PVC to be tapped by fittings suitable to receive each tube/capillary that connect to the pickup foot. Connect the shop vac to one end, and cap the other end. Include a ball valve that can be adjusted to manage the suction on the capillaries. Perhaps the vent isn't necessary if there are several taps.
