Click for YF Listing Service Click for CL Yachts Click for Westport Click for Abeking Click for YF Listing Service
Dock Lines: Double Braid vs. 3-Strand
Discussion in 'General Yachting Discussion' started by LuvBigBoats, Aug 18, 2023.
  1. Pascal
    Btw nobody mentioned megabraid lines but they are ideal for traveling as they are more flexible and coil much better.
  2. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    Good point. I didn't think of that as that would be on the Lux side of dock lines for a sub 60' boat, no? I didn't think past double braid for this project as they are plenty of boat bucks already.
  3. chesapeake46
    chesapeake46 Senior Member
    Do they make Megabraid in small diameters ? I thought Mega was larger in every respect and not well suited for smaller boats
  4. Pascal
    I have some 3/4” but I think they start at 5/8”
  5. gr8trn
    OR/WA/CA/BC
    Just took a look at new England Ropes and they list Mega Braid from 5/8" up to 1.5" which is 16mm to 36mm. Beautiful stuff that.
  6. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    The breaking strength is considerably lower for mega braid compared to double braid and even 3 strand of the same diameter.
  7. Lunderic
    Lunderic Member
    Oceanside, NY
    I slightly disagree with some of the comments. I do use 3/4' for home dock (53' Viking). Home dock calm and well protected. I prefer Double braid for tying to the cleats on floating docks. I differ however on the size to carry when traveling. I snapped a new 3/4' line at a transient slip on the Hudson River when a ferry came through with a big wake. I have also been on Block Island when some storms come through. I use 1" to travel with and prefer 3 strand because I sometimes have to tie up to piles and they catch splinters on double braid. BTW the sound was spectacular when it snapped... sounded like a gunshot.
  8. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    After doing a lot of research I think I'll use 7/8" double braid, with snubbers on the bow and stern given the relatively short length (not much ability to stretch). Breaking strength on 7/8" double braid is 28,100 and on 1" 3 strand is 25,000 (at Miami Cordage). Probably overkill in my marina, but I'd rather be on the stronger side. I don't tie up to wooden pilings so splinters on double braid aren't an issue. I may use 2 pieces of 1" 3 strand to tie up to the mooring ball at Avalon since it stretches more than double braid, and that way I'll have a set of 3 strand if I ever need to tie to wooden piling.
  9. Pascal
    wakes are really tough on lines. If you re going to tie up to a transient dock in a spot with wakes, you definitely need bigger lines.
