Click for Abeking Click for Northern Lights Click for Burger Click for Delta Click for Glendinning
Do You Carry Emergency Shaft Seal Material?
Discussion in 'General Yachting Discussion' started by DOCKMASTER, Jan 3, 2022.
  1. chesapeake46
    chesapeake46 Senior Member
    Kidding aside, I have a roll of self fusing electrical tape, 3 inches wide on board in the event of a hose failure. Would this work on the dripless seal ?
  2. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
  3. C team
    C team Senior Member
    Kent Island
    Very neat product! A little pricey but better than sinking your boat.
  4. OCKK
    OCKK New Member
    Dana Point, CA
    I also looked at the SOS Seal or Sink product. However, I don't think use in an emergency would be as quick as they advertise as you would need to remove your water feed lines to your seal before you can install and completely zip it closed. For me, this would mean removing both the main feed line and the crossover line, and capping those lines so they don't continue to feed water into the boat. Doable, yes, but a few extra steps. Still like the concept and considering purchasing one, but would slow the install for sure.
  5. rtrafford
    rtrafford Senior Member
    Vero Beach
    Yes, but you can pinch the coolant hose against the shaft, wrap it quickly with a rag, and deploy the zips with the hose still in place. The concept here is that the device SLOWS the flow of water. It doesn't stop it. You aren't stopping a water leak with a zip tie. You can only stop a water leak by wrapping the shaft log using a screen door, and then apply flex seal.
  6. rtrafford
    Vero Beach
    Seriously, however, it's a useful product. You can puncture the membrane to make a hole for the coolant hose via a pre-installation, and deploy a zip tie on each side of that hole to account for the coolant line. I think this device is best serving when pre-installed for quick final securing...
  7. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I’ve changed the flax packing in many a boat, while in the water.
    Pulled out the old and installed the new. It is a bit exciting, but I always have a cotton rags and screw driver handy to stop the flow if need be.
    It’s not a deluge of water, but a good flow. Nothing your bilge pump can’t handle.
    Never had dripless units on my boats, but as long as the shaft is still in place filling most of the hole, I assume it wouldn’t be too much water either if you had a failure. Is it like a bellows on an I/O? That sure can let some water in.
    I still would recommend packing cotton screwdriver and a mallet and or the Oakum…
    Simple to tap into place quickly to just stop the flow and regroup to something else if you want.
  8. Capt Ralph
    If it is just the seal leaking, as Cleanslate mentions, it is not that bad of a flow.
    A good bilge de-watering system should keep your ankles dry.
    We are assuming you have a few big A pumps installed.
    However, I remember working the B Bay many years ago, responding to a distressed boat where the log hose self destructed (old age) and a good flow of water was coming up the shaft tube.
    Here is when that can-o-foam came in hand. Oh, south FL water is doable in your shorts (or less) year round.
    On those and later my work boats, cans of this stuff was always around.
    AND this thread reminds me, Last work boat sold. No cans-o-foam around. Need to pick up some.
  9. cleanslate
    Cherry Hill, NJ
    What foam? Expanding foam in a can?
  10. cleanslate
    Cherry Hill, NJ
    What model CC?
  11. mapism
    mapism Senior Member
    Sardinia
    Never heard of that thing, but...
    Eight seals failing over ten years, plus both shafts at the same time last week? o_O
    Its one of the two, methinks: either that guy is just lying, or he'd better spend a bit more for some half decent seals, before inventing emergency patches... :)
  12. Capt Ralph
    Any spray foam in a can with rigid long nozzle.
    Look also for the max expanding type.
    On wrecked boats we used it to fill splits or hull fractures. As a gasket for crude plywood patches. Plug ruptured hoses or drive bellows.
    Anyway to get it afloat or keep it from sinking. Not pretty but worked well on lots of emergency issues.
    Quick, non specific web search;
    https://www.lowes.com/search?searchTerm=spray+foam
  13. Capt Ralph
    Another EX used car sale person.
  14. DOCKMASTER
    Ketchikan, Alaska
    For $130 I think I'll order one of those SOS boots and see how they look and do a test fit while I'm on the hard for the winter. I'll take one for the team and let you all know what I find :):)
    T.T., Capt Ralph and Capt Cole like this.
  15. C team
    Kent Island
    1973 36' Sports Cruiser
  16. cleanslate
    Cherry Hill, NJ
    Commander series?
  17. Adopo
    Adopo Member
    South Carolina
    I have seen a few ads of this type of kit as well, not inexpensive but I am sure worth it if needed.
    https://www.seakits.com
    Hit watch on youtube to check it out.
