Click for Cross Click for Walker Click for Burger Click for Abeking Click for Ocean Alexander
DIESEL FUEL TANK LEAK
Discussion in 'Carver Yacht' started by Mike Michaels, May 17, 2019.
  1. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    I have a pair of aluminum 300 gal fuel tanks in the engine room of my Bertram 54. They deserve closer inspection. I have observed only minor corrosion in the past. I sprayed them with corrosion block.
  2. Pascal
    Corrosion usually starts from the inside out, at the bottom from water accumulating at the bottom. Or from the outside if the tank ate set on plywood.
    I hate alum diesel tanks, most are a ticking time bomb
  3. Jnicholas
    Jnicholas Member
    Long beach ca
    I know I’m late to the party on this thread but have related question. I have twin aluminum tanks in my 2000 450 voyager. No leaks a little dusty on top as they are quite close to deck above. I keep tanks relatively full, with additive to help keep diesel clean. No inspection port so do I just wait for leak to develop or can I be proactive to extend tanks life?
    There's not much you can do to extend the tanks life short of rinsing any salt off of the outside and keeping good o-rings on your fuel fill caps to prevent water inside of them.
  5. Capt Ralph
    Ensure the bottoms of the tanks stay dry also. Water can collect behind and under the tank and start eating them up from the outside.
