Click for Walker Click for Cross Click for Nordhavn Click for Ocean Alexander Click for Abeking
Diesel Engines Running Underloaded / Lube Problems?
Discussion in 'Engines' started by C4ENG, Jun 13, 2012.
  1. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    It's alright. It's an engineering thing
  2. Yachtjocky
    Yachtjocky Senior Member
    fun
    Carl, just a bit of fun from "US" old fellows teaching a young one a wee lesson that he will surely remember, check your facts and show a little respect to your elders was something drummed into me 40 years ago.
    Obviously my reference to the Holiday Inn was said in jest and as you may know comes from a funny commercial over here in Florida. :cool:
  3. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    I do not know. Coolant, sea water, air after your turbo? Can you tell me?
  4. Yachtjocky
    temps
    Now you are taking the P155, how can you not know that and yet post the BS you did earlier in this thread.
    also another little hint, do you know the difference between your F's & C's. ;)
  5. Yachtjocky
    Food for thought
    A little bit of advanced thinking, is this how to produce alot of acid ?
    "A second, widely acclaimed technology for reducing
    NOx pollution from diesel engines is the “Humid Air Motor”
    (HAM). This technology is able to reduce NOx formation
    by up to 65%. In the HAM system the turbocharged
    combustion air is saturated with water vapour produced
    aboard the ship using sea water and engine heat.
    This lowers the temperature peaks in the combustion
    chamber, which are normally the main reason for NOx formation.
    HAM is characterised by extremely low operating
    costs due to sea water usage, decreased lube oil consumption,
    very low maintenance costs and a very high
    availability factor" :confused:
  6. captholli
    captholli Senior Member
    In The Bilge
    Humid Air Motor, Now we're talking!! Never heard of it but will do some research. Excellent addition to this thread, Glad to learn something new and learn from this thread. Well done!
  7. Ward
    Ward Senior Member
    Vancouver BC
    Someone who's been on here a bit can quickly figure out who knows what they're talking about and who doesn't. One common sign of a person who's out of their depth (or BSing, or trolling) is that they start off very authoritative and serious, then switch to lighthearted and flippant so that they can dismiss the whole exchange as just bantering.
    You're correct about it poisoning the well, though. It'd be better for everyone if you didn't have to spend your time/effort calling out misinformation and could, for example, add to CaptJ's post about what the issues might be in a trans-Atlantic passage at ~50%.
    Absolutely. The charge air temperature is usually your engines intake air temperature measured after it goes through the aftercooler, before it goes directly into the engine. This will alert you to how well your aftercooler is doing it's job in cooling down the charge air after it has been heated (a result of compressing air) by the Turbo's. Seawater is generally used to cool off the charge air within the aftercooler the same way a heat exchanger works, you have air flowing through the aftercooler, and seawater contained within a seperate section that the airflow flows past similar to a car radiator. I would say seawater cooled aftercoolers are most common on recreational marine diesels.
  9. Yachtjocky
    I see you have been reading up on your engineering J. Pretty good answer :p
  10. Capt J
    I haven't read up on any engineering, I've always known what I know for the most part. I've gotten better in speaking or making sure my terminology is correct.
  11. Marmot
    a version of that technique has been used on gas turbines for decades. "Fogging" is a method that sprays a mist of demineralized water into the inlet to cool the inlet air and increase power output.
    I used to fly an aircraft that used water injection in front of the first stage compressor wheel to boost take-off power in "hot and high" conditions. It really makes a difference. In recips it lowers the combustion temperature and reduces NOx as stated by Yachtjocky.
    It should be noted that the water used in a HAM system is not salt water, it is saturated water vapor distilled from sea water using waste heat in the same manner as the watermakers on those ships. Instead of condensing the vapor to make fresh water, the vapor is delivered to the engine intake.
  12. Yachtjocky
    terms
    OK then, try removing "usually" and replace with "always" and you will be a real engineer ;)
  13. Yachtjocky
    water
    There was a process that we were asked to try out over 30 years ago where the heavy fuel was forced through two rollers with a very small clearance and fresh water was introduced on entry to them.
    The theory I believe was to force the water & oil to mix to achieve the same as what we are talking about. Unfortunately there was so much s--t in the fuel it wore the rollers out and after a few days of rebuilding fuel pumps and injectors our company pulled out of the experiment. Plus we did not have the electronics avaliable in those days so the monitoring consisted of a faucet, a water hose and sight glass and with that we where expect to change the world.
    FYI. CaptJ, we could change the fuel pumps on those big old engines while at sea and with them running and even adjust them but you did have to keep your fingers away from the plungers. :cool:
  14. Marmot
    The shipping press has had quite a bit of noise about fuel emulsions lately. Maersk is currently in trials of a water/fuel emulsion project. Fuel emulsions are heralded as the greatest thing since reduced manning.
    There are a couple of benefits, most of the proponents are now pushing the economy angle in that you can use cheap heavy fuel and when blended with up to 30 percent water it becomes an intermediate fuel like IFO 380 and is easily handled at lower temperatures.
    It is supposed to improve combustion quite a bit and reduces soot, cools the reaction zone and reduces NOx. It evidently works but like your trials, the blending device is the bottleneck.
    I would think that emulsions would be better for slow steaming than HAM since there isn't much waste heat left these days anyway.
  15. captholli
    In The Bilge
    I've worked with a few GE turbines that were earth bound (power generation) and not aviation where they were utilizing a cleaning system installed for the compressor core that would use highly atomized water to clean and remove any unwanted residue from the blades either spooled up off line, or on line @ normal operating temps so it makes sense that a cleaner compressor would give extra kick of thrust plus the benefit of cooling the air and making it more dense with vapor. But you would also figure that aicraft turbines encounter so much moisture in the form of clouds and rain that their compressor cores would be relitively clean?? Just watch out for the Ducks and cranes!!:)
  16. Marmot
    If he knew anything about internal combustion or fuel characteristics this thread wouldn't exist.
    C4ENG's guy may have been talking about exhaust temps but that is a completely different animal. And if he was talking C instead of F then his numbers are equally bogus.
    The 650* figure (if it is C) is what we may expect the compressed charge air temperature to be at start of injection. At the end of ignition lag, when the fuel starts to burn, the temperature rises rapidly to over 1000*C in the combustion zone.
    There is no practical way (or reason) to measure combustion chamber temperatures in the combustion zone and present that information to the operating engineer. The temperature of combustion is essentially the same at idle as it is a full load, the difference is the amount of heat transferred to the cylinder and piston.
    There is a difference between temperature and heat, that should have been in the class notes somewhere.
  17. Marmot
    We also use a turbocharger compressor (and aftercooler) cleaning system like that on large diesels but the water fogging is there to cool the inlet air to increase its density, not to clean the compressor. On aircraft turbines it is used (at least in the aircraft I flew) only on takeoff when the calculated power (torque as it was a turboprop) was below a certain amount due to hot low density inlet conditions created by weather and field altitude.
    The fogging used on terrestrial GT plants uses the cooling produced by evaporation to increase the density of inlet air and increase power output. As you know, turbines are so sensitive to inlet conditions that most terrestrial plants now use a refrigeration system to cool the inlet air. That is why a GT powerplant has that huge louvered structure at the inlet side and another structure with a cooling tower nearby, it is the chill water plant. The power increase is enough to pay for that system and more.
  18. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    Here is something I have been meaning to find an answer to...
    On the 3512Cat sea water cooled aftercooler models (opposed to the engine coolant aftercooler models) you will see the engine display screen shows the aftercooler temperature. However the aftercooler temperature that is displayed is not the charged air temp. It is measuring the sea water entering the aftercooler. (I had that temperature sensor fail on me once and it caused a high temp alarm at 200F+ I believe it was, and the engine shut down on alarm. Fortunately we were close to the dock and I started the engine in alarm override and got us in).
    Changing the sensor caused me to wonder why CAT does not actually measure the charged air inside the aftercooler, but they chose to measure the entering sea water to the aftercooler shortly after the raw water pump. I do not see how in any circumstance the sea water temp could get high enough to cause alarm. Even if the water was cut off for what ever reason, then there would be other alarms to signal that issue and still can't see that sensor measuring over temp then.
    Maybe you know something that I do not?
    Lesson learned, keep spare aftercooler sensors on hand as those sensors sitting in sea water fail at a faster rate than the other sensors and when they fail, your engine shuts down. It will more than likey happen at 2 to 3AM as well.
  19. K1W1
    Sea Water and SCAC Manifold Temps on CATS
    From my experiences CAT do measure this temperature.
    I just looked on CAT ET which is a remote view of what's available on the local MPD.
    Direct Sea Water Cooled Charge Air Coolers on C18's call it Manifold Air Temp, the sensor itself is towards the front of the Cooler Hsg on the Upper Side
    On a SCAC 3516 it is called the same and the sensor itself is forward ontop of and passing through the casting that forms the base for the Charge Air Cooler retaining flange.
  20. Capt J
    YUP, and also the CAT's will monitor/display fuel temperature as well and that will show how well the fuel cooler is working.....Some CAT models have the fuel cooler integrated into the heat exchanger.
