Click for Delta Click for Ocean Alexander Click for Cross Click for Burger Click for Nordhavn
Detroit Diesel Starter set-up
Discussion in 'Engines' started by RVinMICH, May 16, 2016.
  1. Mjkrawczy
    Mjkrawczy New Member
    Muskegon Michigan
    My worst fear came to light. STBD is locked up.
    Start removing Injectors tomorrow and see what gives
    Oh Sheet,
    I felt it would come to this but my fingers were crossed for you.
    The Detroit injector hole thru the head is pretty small. A faster path to look at the lungs is to pull the blower off.
    You will be doing that anyway to clean it up. There is no fancy gear timing here.
    Remove the blower drive shaft from the rear, undo the fuel hoses, hold down bolts, back gland clamps, back oil connect, slide it forward and up by the front.
    Below is the air box and views of the pistons thru the liner ports.
    Unless there was a water line issue (sank) there should not normally be water in the lungs.
    Wet and damp air usually comes up the exhaust and rust up the valves and lungs.
    You are going to pull the heads soon also. At least the blower will be out of the way when you reach over the motor to get to the far head.
    Stuff is heavy with lots of edges and corners that like to smash fingers.
    Be careful.
    Is this a wood or plastic boat?
  3. Mjkrawczy
    Muskegon Michigan
    Thanks for the advice.
    Appreciate. Took Inspection Covers off. Just seen one Piston with some Rust. Can’t see tops of other pistons. Have to start to disassemble.
  4. Mjkrawczy
    Muskegon Michigan
    Left off it’s a wood boat
  5. Capt Ralph
    Yep, Side covers. Was not sure you would have the room to get at them.
    But, You witnessed the damage.
    Do you have room to drop the pan? Planning on an in-frame rebuild?
    Those are one piece crank seals on the end. Your not going to be able to replace them during an in-frame.
    This also means one main cap at a time comes off as to not damage these crank seals.
    Remember, these are wet liners, drain the coolant.
    When you get the heads and sump pan off, unbolt the rod caps, as you turn the crank, the pistons with liners will come up for you to grab and pull aweigh. Watch out for the crank throw coming back around that the other rod studs to not strike the rod journal surfaces on the upstroke. A 1x1 block can be placed between the rod journal and rod to push it up further for the (2?) near TDC pistons to get pushed up further. A third hand helps here.
    It is the rods, pending the kit, maybe the pins you are going to re-use.
    Now, time to get realistic; rebuilding a 53 may cost more than the value of this wood boat.
    AND, chances are, you will be rebuilding the other engine anyway.
  6. Mjkrawczy
    Muskegon Michigan
    Not much room under oil pan.
    Tomorrows another day..
    thanks again
  7. Mjkrawczy
    Muskegon Michigan
    Update…
    Was finally able to get the Injectors all out.
    No Fluid on any kind. Must be that one Piston holding up the Show.
    Sprayed PB Blaster in all Cylinders. Will try tomorrow afternoon to Rotate the engine Manually.
  8. boatpoor
    boatpoor Senior Member
    Add some Marvel Mystery Oil to each cylinder for a day before trying to rotate it again.
  9. Mjkrawczy
    Muskegon Michigan
    Will do
  10. Mjkrawczy
    Muskegon Michigan
    Anyone come up with an Electrical Diagram for this setup?
  11. Capt Ralph
    uh?
  12. d_meister
    d_meister Senior Member
    La Conner, WA.
  13. YachtForums
    Fixed.
    d_meister likes this.
