Click for CL Yachts 99X Click for Ocean Alexander Click for Ocean Alexander Click for CL Yachts Click for Burger
Detroit Diesel 6-71ti starting issue
Discussion in 'Engines' started by Posterboy91, Jan 23, 2019.
  1. Posterboy91
    Posterboy91 New Member
    Fort Lauderdale fl
    so I did this and the engine starts on the first crank. issue im having with the other engine now is that I can make full rpm out of gear but ounce the engine is under load im down about 350-400 rpm. I just had the props sent out and redone and changed the turbos out for new ones with no change. suggestions?
  2. Pascal
    Throwing parts at a problem is a lousy way to diagnose an issue a good DD guy will likely solve quickly. Props aren’t going to cause a sudden 400 rpm loss unless they re mangled up.
    Start with the basics. Fuel filters (prim and sec), rack etc.
    Need to get a good Detroit Diesel guy out. But if the props didn't hit anything, the turbo's looked fine, you either have a bad injector or dead cylinder to lose 350-400 rpms usually.
  4. Pascal
    If you had a dead cyl or injector, taking exhaust manifold temp with an IR thermometer will show you which one is not firing at 100%
  5. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    The IR guns are cheap at Harbor Freight, about $20 and are a good tool to have on-board for trouble shooting.
  6. Boomer
    Boomer Senior Member
    Seminole
    He said he had his props redone...did they change the pitch on them?
  7. Posterboy91
    Fort Lauderdale fl
    yes they were changed from 24x26 to 24x24
  8. Boomer
    Seminole
    Scratch my thought...if you went the other way, that would have caused your issue
  9. Capt Ralph
    You kids are on this.
