Click for Walker Click for YF Listing Service Click for CL Yachts Click for Ocean Alexander Click for Abeking
Detroit 12V71
Discussion in 'Engines' started by Sam Bellows, Apr 13, 2022.
  1. Pascal
    Combined. See my last reply. I never include gen because i run the gen 24/7 so I keep track of that burn separately.
    the key is to not exceed hull speed. For a 67 footer hull speed is going to be 10kts. Not 10.5 kts… an extra 1/2 kts above HS will Cost you 30% more fuel. An extra knot? Close to double
    HP is fuel
    Crudely, if each engine is delivering 250 HP to the same props and same ratios, Yes.
  3. Capt Ralph
    Hull speed can be calculated by the following formula:
    v h u l l ≈ 1.34 × L W L {\displaystyle v_{hull}\approx 1.34\times {\sqrt {L_{WL}}}}
    [​IMG]
    where
    L W L {\displaystyle L_{WL}} [​IMG] is the length of the waterline in feet, and
    v h u l l {\displaystyle v_{hull}} [​IMG] is the hull speed of the vessel in knots
  4. Sam Bellows
    Sam Bellows New Member
    Galveston
    I wholeheartedly appreciate your willingness help and give me some numbers to go on. Im a diver and the ability to use it as a live aboard not to mention a dive boat or occasionally as a chartered dive boat and run it kinda affordably, I’m not expecting a half gallon an hour, is rather important. I’m wanting the yacht equivalent of a Chevy suburban. The places I’d like to go in the Caribbean and gulf are far enough out I don’t want to do it in a 30’ bathtub.
  5. rusty882000
    rusty882000 New Member
    New Zealand
    Any idea what the Detroit 12V-92TA 8122-7400 rated shp 775@2300 rpm would burn at 1800rpm cruising?
    Cant find any performance data on this engine.
    Correctly loaded, 34 (US)GPH.
