Click for Ocean Alexander Click for Delta Click for Glendinning Click for Abeking Click for Westport
DDEC 6v92 no electronic throttle control
Discussion in 'Electronics' started by Hyak, Jun 16, 2014.
  1. K1W1
    + 1 on that part.
    During the charge cycle the liquid in the cells of wet lead acid batteries splits off into hydrogen and oxygen - hence the need to ventilate battery compartments.
  2. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    Glad the Sea Deuce engines are the non DDEC versions...
    The DDEC systems have always been very reliable from what I have seen. They're a good system and pretty much what MTU is still using today. In all honesty they make the 2 cycle Detroits run like a modern 4 stroke. Providing the motor doesn't have a dead cylinder. They start right up almost always, even when it's 65F outside, they have clean exhaust within seconds, and they run smooth throughout the RPM range, they also have a lot of nice information features on the display- load, fuel pressure, fuel burn, all of the temps, boost pressure etc.......
    Problem was, they programmed the DDEC'son the 2 stroke Detroits to where every engine was pretty much maxed out HP wise......More HP less longevity as we all know......
