Click for Ocean Alexander Click for Nordhavn Click for Abeking Click for YF Listing Service Click for Walker
Data Backups?
Discussion in 'YachtForums Yacht Club' started by K1W1, Feb 9, 2012.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    That's an intersting reply, I must read thru again, and re-absorb it.
    The first external HD I ever bought sold me on the idea that it would just go thru and 'update' all of those files, etc you already had on it. Then it would add on the new ones. Problem is I could NOT understand the software and instructions it came with...so I just gave it to my stepson and bought another brand. :confused:
    I believe there are some softwares that are written by people whose brain functions in a different way than mine, and understanding their 'system' gets a litlle difficult...no? :confused:
  2. brian eiland
    So those ubiquitous thumb drives are pretty safe storage medium?
    Is there a lifespan on the data stored on them? I had read their was a lifespan for data (at least music quality) stored on CD's ?
  3. Ward
    Ward Senior Member
    Vancouver BC
    I assume Codger is talking about a drive enclosure that does RAID1 - mirroring two drives, the enclosure keeps the data the same on both of them. This is one cheap one: 3.5in Black USB 2.0 to Dual SATA Hard Drive Enclosure with RAID | StarTech.com Canada
    RAID5 that Wickie mentioned is generally NOT used on servers any more. The basic idea is great - put 4-6 identical drives in a box, and the RAID system spreads the data out over all the drives so that if one fails, you can replace it and keep going. But with modern large hard drives, if one drive fails, it can take a looooong time to rebuild the data from the remaining drives. If, during that rebuild, there's another error, you can lose everything.
    RAID6 is pretty much the same as RAID5, but with the data spread over an additional disk, so you can survive 2 failed drives.
    Hard drives do fail over time, turning them off and on (spinning them up and down) is generally considered to be worse than leaving them running all the time. One common problem is when you take a drive that's always worked fine, and put it away as an archive. It sits in an acceptable environment for a couple years, then you plug it in to pull some data off and find it doesn't work.
    My first thought for why you can't access data on an external drive on one PC would be permissions and/or admin access on one of the machines.
    Other than expensive enterprise-level backup software for servers, I don't trust most tools to deal with incremental or differential backups. I use SecondCopy (other tools can do the same) to sync files between drives. Whatever drive I am using as the master, I replicate all the files to the other drives. I don't archive old files onto any other drive, or DVD or anything. All my files are on my master drive and I have a bunch of duplicates of that drive. It's the simplest thing I could come up with.
    I believe that fairly lightly used thumb drives are safe for a long time. If you are writing and updating a lot of data on them, there's possibly an issue with them "wearing out." The memory cells can wear out, but it takes a lot of repeated write/erase cycles to do it. On SSDs, the firmware moves data around to avoid it, but as far as I know thumb drives don't do a lot of this "write leveling."
    CD-Rs and DVDs are the most problematic, in my opinion. First of all, you have to get high-quality discs if you want to have any hope of them lasting. Then you have to hope that the new optical drive you get in 5 years will still be able to read the discs. I have some old CD-Rs that were very high quality disks, but written way back on a 2x CD-R drive... By the time drive speeds were up to 32x, the old disks were almost unreadable.
  4. AMG
    The iomega was connected to power but not to the computer and the power was off, not in standby. Suddenly I could hear it start and stop a couple of times and when I tried to get it working it was dead!
    I searched on the net and found it has happened to others as well, probably some bad components. It may be possible to take the two disks out and fit in another drive or a computer to restore the data, but I have not done that yet.
    I have a "Time Machine" now that is doing a backup mirror every hour and in between I am backing up files between laptop and desktop computers, but I am thinking of getting an SSD device that I can store elsewhere.
  5. rodsteel
    rodsteel Member
    Oregon
    Brian,
    I agree with Ward's comments.
    Ward,
    I find that using two drives and alternating the Ghost duplication every month or so reduces the chance of storage failure (I have also used your software mirror solution in a production environment with some success - via MirrorFolder software - but maintaining a duplicate system at home does not make sense for me - especially since only the files on my thumb-drive are "active").
    N.B. Most of the time I am only adding new files or extending old files on the thumb-drive, not over-writing or deleting much.
  6. brian eiland
    Are the good external HD's really any different that those HD in our desktop computers? Those desktop HD's seem to have a fairly long life.
    I believe I was told that one should NOT move it around or jossel it while it is on (spinning).
  7. Ward
    Ward Senior Member
    Vancouver BC
    For 3.5" drives (normal desktop size), most manufacturers have an "enterprise" class that's rated as more reliable (and they cost more) than "consumer" level. If you buy an enclosure with a drive in it, you get whatever drive they put in there, often a consumer drive, but not always. It's possible to buy an empty enclosure and put your own drive in it, I've done that in a couple cases and bought Western Digital's more reliable RE drives instead of Caviars.
    I don't have experience a lot of 2.5" drives, but I know the one I use as my master drive is almost 4 years old and has survived being carried around almost every day. (but in an anti-static envelope inside a padded case). Many (I would guess most, but I'm only really familiar with WD) 2.5" drives are designed to cope with the rougher use they'll get in a laptop.
    Absolutely. The read/write heads are almost touching the drive surface when they're in use, and even though they're very very light, a bump can cause a head crash and loss of data. Lots of people (including me) have killed drives by knocking them off a desk when they're being written to.
  8. marcus_l
    marcus_l New Member
    stockholm, sweden
    backup
    After a friend had a unwanted visitors a few weeks ago where they not only stole all laptops, they also stole the two usb drives used for backup, i've now use dell's datasafe service (https://www.delldatasafe.com/). 2GB data free. I got the 100GB data option since I have loads of photos.
    All I had to do was to install a small agent on all of my computers and backups are made :)
    Remember that it isn't a backup unless you have the data on more than one location, if you save your images to an usb drive and then delete it from the PC, it is no longer a backup :)
