Click for Burger Click for Delta Click for Glendinning Click for Burger Click for Abeking
Corroded pipe nipple
Discussion in 'Technical Discussion' started by Trak, Jan 14, 2020.
  1. Beau
    Beau Senior Member
    Beaufort, NC
    Stupid me - I forgot GOPro's are waterproof, DUH.
  2. chesapeake46
    chesapeake46 Senior Member
    Beat me to it !!
    My marina's store is a distributor for Buck Algonquin and they stock almost any nipple you might need up to something like 2.5 " or more.
    Ironically I just got off the phone with them for a different matter and asked them if they had a bronze source !
    Prolly just need to find a local B.A. distributor.
  3. rtrafford
    rtrafford Senior Member
    Vero Beach
    I think I have about 150 lbs of various brand new bronze fittings in a bucket. I use it for ballast.
    There is always Marelon and grey (sch 80) PVC.
  5. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    No kidding...that's a great idea. I've got one on the boat , lol I think that's where it is. Haven't used it in a while. I used it for skiing , mounted on my helmet . Ya'll would be proud of me! :)
    I'll try it under water strap it to my boat hook.
  6. cleanslate
    Cherry Hill, NJ
    Really ? Doesn't look like a wood bottom . Thsts in real good shape. Or is it glass over wood ?
  7. cleanslate
    Cherry Hill, NJ
    For some reason, I've never seen a wood boat with a transom plate. I do not know why. But may be you have a 12 volt source getting into the bilge/bilge water causing this ...a bilge pump or pump wire , old wire in general hanging loose in the bilge etc.
    As far as bonding goes , to bond or not to bond ? Some wood boats and glass are not bonded at all so not to carry stray current to all fitting and let it eat up just one , I belive is the though behind this . Anyway it is an art to each individual boat .
  8. Marblehead01945
    Marblehead01945 Member
    Marblehead
    The boat is cold molded. There is no transom plate. I am not sure why but I have heard that you need to be careful to not over zinc a wooden boat and also someone told me "they don't look good on sportfishing boats" go figure (no swim platform to hide it). The bilge areas in this boat are usually bone dry. Anyway, we'll continue to hunt it down as it hasn't been a problem every before.
  9. Beau
    Beau Senior Member
    Beaufort, NC
    The theory of the bonding system is that at its end there is a sacrificial zinc or other less noble metal which protects all the attached fitting. Once the fittings are properly connected they become one unit with the need for only one zinc source. Even with a/c current in the water the fitting won't be harmed as long as the less noble zinc is there. Imo leaving bare fittings to their own is courting disaster? Many older wooden boats have a keel located ground, some times in the form of copper tubes or zinc bars . I believe the more modern ones, like Jarret use the divers plate which can also be attached to the bottom. The transom is only one location.
    Someone has to do a full and competent survey of the galvanic and other induced currents flowing both in and outside that boat.
  10. Pascal
    You can compare a cold molded boat to a wooden boat. Completely different. A cold molded hull is closer to a fiberglass hull except that the glass is replaced by thin strips of mahogany
  11. Capt J
    Overzincing doesn’t apply to cold molded. You need anything having saltwater through it bonded, to a zinc.
  12. Pascal
    Obvious typo in my reply. I mean You CAN NOT compare ..
  13. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    It is a classic case of dezincification of a brass nipple: http://www.werc.com/2016/07/28/dezincification-failure-of-brass-components/
    Brass fittings have no place on marine applications used in raw water flow.
  14. Beau
    Beau Senior Member
    Beaufort, NC
    teach me. I've often heard what I thought was a myth about over zincing - is it a real thing?
  15. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Well, when the waterline disappears.........:D
  16. Beau
    Beau Senior Member
    Beaufort, NC
    Capt J
    Help me understand if over zincing is real or a myth. Thanks
  17. Capt J
    I had an issue with zincs not lasting and galvanic corrosion on a yacht. It was explained to me that overzincing could be a problem and if overzinced by quite a bit, could create electrolysis because of that. Some hull materials are more susceptible to being overzinced and some manufacturers like Volvo with their IPS and Yamaha outboards are foregoing zincs altogether and using Aluminum as the sacrificial anode instead of zincs.
  18. PacBlue
    Dana Point, Ca
