Click for CL Yachts 99X Click for Ocean Alexander Click for Delta Click for Cross Click for Northern Lights
coolant issue on 12 v 92s
Discussion in 'Engines' started by bluesuit, Feb 26, 2014.
  1. bluesuit
    bluesuit Member
    new orleans
    soot on transom
    what could cause this?? no smoke at cruise.
  2. Marmot
    Diesels emit lots of soot and other particulates even if you can't see any smoke.
    Is it a lot more soot than you normally see on the boat and which side of the transom is it heaviest?
    BTW. I have seen many bad reliabilt rebuilt injectors right out of the DD box.
  4. bluesuit
    bluesuit Member
    new orleans
    Both sides. Port engine just rebuilt. New injectors (port). Two had to be returned to s&s because they were stuck. 54 Bertram. Been told this is a characteristic of boat.
    It might be......Do both engines achieve RPMs at WOT? How sooty are you talking about? Do you have a picture? It's not uncommon for boats with DD's and older mechanical diesels to get some soot on the transom......and even some newer ones do as well.......
