Click for Mag Bay Click for Nordhavn Click for JetForums Click for Walker Click for Burger
Control panel ddec 6v92 ti
Discussion in 'Hatteras Yacht' started by Cooter Brown, Sep 25, 2019.
  1. Cooter Brown
    Cooter Brown New Member
    43ft Hatteras, 6v92ti, 1998. Engines fire right up. No problem. Mtu reading panel reads fine, rps, temps, etc. When trying to engage throttles and gear shift, shifter panel is dead. No indicator lights, nothing. Checked controls in tuna tower, nothing. I'm sure its something simple but cant figure out what it could be.
    If I remember correctly, DDEC control panels were usually on their own box and could switch from engine batteries or house batteries for the supply......it's probably on house batteries and your house batteries are bad or dead.
  3. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Are your starters 12 or 24 volt? Are you controls 12 or 24? I know they switched to 24v in the later years of the DDEC. My starters are 24v but the DDEC are 12v. If yours are the same you likely have a Vanner or similar 12v power supplying the DDEC's. If this has failed you get no power to the controls. But it's odd that the everything else is fine. You might have a simple blown fuse or bad connection to your station selector switch/activation button.
  4. Cooter Brown
    Its something simple. I'll recheck fuse panel. Thanks.
  5. Capt Ralph
    Didn't one of the other YF members find a bad fuse for the same issue?
  6. Cooter Brown
    Not sure. Checked breaker panel and cant fine anything tripped. Will take tester and see if we're getting power to the selector panel and will go from there. Thanks
  7. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Cooter ? Aren't you the mechanic from Dukes of Hazzard ? I'm sure you'll figure it out ! . Sorry good luck, I have nothing to offer. But you'll get it.
  8. Cooter Brown
    I confident that I will. Thanks
  9. Cooter Brown
    Wish I had a chief engineer on this one. Great boat though.
  10. cleanslate
    Cherry Hill, NJ
    Got Ya. But there was a post on this I think about a year ago. Search around here. I think there is a fuse with in the controller it's self ? I think ? But there was a post here somewhere .
    I have one helm station and good old cables to control my DDs . Less chance of failure , cables that is. But it sounds like you have three stations ...yikes! Lots of stuff needed to control the engines.
  11. Cooter Brown
    Ahaaa!,, it was a loose wire connecting the on and off panel. Resecured it. All is good. Thanks for the help guys.
  12. Capt Ralph
    Lucky Dawg. Ya got it.
    Sometimes it's just that simple, Ya just got to find (trip over) it..
    Your a DDEC tech now.
