Click for YF Listing Service Click for Westport Click for Cross Click for CL Yachts Click for YF Listing Service
Charcoal Vent Filter Location?
Discussion in 'Sunseeker Yacht' started by Kwingall, Jun 15, 2026.
  1. Kwingall
    Kwingall New Member
    Tucson
    Anyone know where the charcoal filter is located on the 2005 46' Portofino? I've been crawling around this boat trying to find it but must be blind or somethingo_O Thought it would be near the holding tank.
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Assuming you're talking about a filter on the holding tank vent hose?
    Find the holding tank, identify the vent hose, trace the hose forward from that? Find the external vent fitting, identify interior hose that's attached, trace backwards from that?
    The filters are often (usually) thing and cylindrical...
    -Chris
  3. Pascal
    They’re usually up high in the vent line closer to the vent than the tank. If you know which hole is the vent then it should be behind often in the back of a closet or cabinet depending on the layout
  4. Kwingall
    Kwingall New Member
    Tucson
    Excellent! I think I just didn't trace it far enough or behind the right cabinet. Thanks for the advice.
