My husband and I are helping a friend change the name on his 2005 Carver and we have run into a problem. We have taken the old lettering off and have wet sanded it several times, however the letters are still visible. Do y'all have any advise on how to get rid of the ghost letters so they won't show up when we put the new lettering on? Thank you in advance..
Someone else will chime in I'm sure, but having managed a detail shop in the past, the only solution we gave our marine customers was that it would have fade to match. We had tried many products and processes to get the old area to match where the letters came off. We had one we were able to get to match, but, it was a junk boat the owner had given us to test on. We ended up sanding nearly through the gelcoat. This may have been age though. I do not work in the industry any longer, but I will talk to my friends to see if they have come up with a solution.
I'm assuming it was vinyl letters you removed and not paint. I'm hoping also it's a light colored transom. Do not get to aggressive with rubbing , sanding or any abrasives. Clean it, final polish (no wax) install the new (vinyl?) name, 1 month later wax it & be happy. Mother nature will resolve the rest in short time. You can keep your transom towards the sun it would help. Re-coating or painting the transom is an expen$ive alternative. Now, the important part of name changing; There is a ceremony to adhere to. It may help the old name fade even quicker pending the quality of the champagne and if I'm invited.
Thank you both for responding, yes they were vinyl, and yes light colored transom. I have tried lightly sanding it and then trying to match the paint, but none of the colors are quite right. I will just let them know that there will be some show of the letters underneath. I was not aware that there is a ceremony involved, however I did hear from an old captain that is very unlucky to rename one. Hopefully the new lettering we paint on will do a nice cover up. Thank you again for the advise.
Here is a simple ceremony. We cover the ships new name till christening and asking for new ships blessings. The tags of all of the ships previous names we get engraved at a pet store. According to legend, each and every vessel is recorded by name in the Ledger of the Deep and is known personally to Poseidon, or Neptune, the god of the sea. It is logical therefore, if we wish to change the name of our boat, the first thing we must do is to purge its name from the Ledger of the Deep and from Poseidon’s memory. This is an involved process beginning with the removal or obliteration of every trace of the boat’s current identity. This is essential and must be done thoroughly. In purging your boat, it is acceptable to use White-Out or some similar obliterating fluid to expunge the boat’s name from log books, engine and maintenance records etc., but it is much easier to simply remove the offending document from the boat and start afresh. Don’t forget the life rings and especially the transom and forward name boards. Do not under any circumstances carry aboard any item bearing your boat’s new name until the purging and renaming ceremonies have been completed! Once you are certain every reference to her old name has been removed from her, all that is left to do is to prepare a metal tag with the old name written on it in water-soluble ink. You will also need a bottle of reasonably good Champagne. Plain old sparkling wine won’t cut it. Since this is an auspicious occasion, it is a good time to invite your friends to witness and to party. Begin by invoking the name of the ruler of the deep as follows: Oh mighty and great ruler of the seas and oceans, to whom all ships and we who venture upon your vast domain are required to pay homage, implore you in your graciousness to expunge for all time from your records and recollection the name (here insert the old name of your vessel) which has ceased to be an entity in your kingdom. As proof thereof, we submit this ingot bearing her name to be corrupted through your powers and forever be purged from the sea. (At this point, the prepared metal tag is dropped from the bow of the boat into the sea.) In grateful acknowledgment of your munificence and dispensation, we offer these libations to your majesty and your court. (Pour at least half of the bottle of Champagne into the sea from East to West. The remainder may be passed among your guests. It is usual for the renaming ceremony to be conducted immediately following the purging ceremony, although it may be done at any time after the purging ceremony. For this portion of the proceedings, you will need more Champagne, Much more because you have a few more gods to appease. Begin the renaming by again calling Poseidon as follows: Oh mighty and great ruler of the seas and oceans, to whom all ships and we who venture upon your vast domain are required to pay homage, implore you in your graciousness to take unto your records and recollection this worthy vessel hereafter and for all time known as (Here insert the new name you have chosen), guarding her with your mighty arm and trident and ensuring her of safe and rapid passage throughout her journeys within your realm. In appreciation of your munificence, dispensation and in honor of your greatness, we offer these libations to your majesty and your court. (At this point, one bottle of Champagne, less one glass for the master and one glass for the mate are poured into the sea from West to East.) The next step in the renaming ceremony is to appease the gods of the winds. This will assure you of fair winds and smooth seas. Because the four winds are brothers, it is permissible to invoke them all at the same time, however, during the ceremony; you must address each by name. Begin in this manner: Oh mighty rulers of the winds, through whose power our frail vessels traverse the wild and faceless deep, we implore you to grant this worthy vessel (Insert your boat’s new name) the benefits and pleasures of your bounty, ensuring us of your gentle ministration according to our needs.(Facing north, pour a generous libation of Champagne into a Champagne flute and fling to the North as you intone Great Boreas, exalted ruler of the North Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your frigid breath.(Facing west, pour the same amount of Champagne and fling to the West while intoning Great Zephyrus, exalted ruler of the West Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your wild breath.(Facing east, repeat and fling to the East.) Great Eurus, exalted ruler of the East Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your mighty breath. (Facing south, repeat, flinging to the South.) Great Notus, exalted ruler of the South Wind, grant us permission to use your mighty powers in the pursuit of our lawful endeavors, ever sparing us the overwhelming scourge of your scalding breath. Of course, any champagne remaining will be the beginnings of a suitable celebration in honor of the occasion. Once the ceremony has been completed, you may bring aboard any and all items bearing the new name of your vessel. If you must schedule the painting of the new name on the transom before the ceremony, be sure the name is not revealed before the ceremony is finished. It may be covered with bunting or some other suitable material.
Compounding (or even Soft-Scrub with bleach) will help, especially along the edges of the old lettering so as to blur the lines a bit, but it's hard to beat the job nature does over years of exposure. Some prefer the look of a white box over the old lettering and under the new name, but I don't. Some things you just have to live with. Exposing the transom to the sun will help blend. Also using a colored wax when done. I don't recommend "sanding" gelcoat unless you know exactly what you're doing. I'm a bit surprised to here that you're painting the name unless this is a very expensive boat. The fact is that vinyl lasts longer, is easy to apply and consistant. No "artistic differences".
Nycap only addresses Neptune. However, his wonderful wife Salacia must be honored as well. She is the personification of a calm and sunlit sea. I previously posted the way to honor her. It's very important. A happy Salacia is a happy Neptune. http://yachtforums.com/threads/new-to-forum-purchasing-1974-60-foot-roamer.21056/page-3#post-209707
We use a gentleman here in Jax for our customers. He produces & applies vinyl and paints. Sometimes that free hand and gold just can not be done with vinyl. However, the paint does need maintenance and as NYCAP mentioned, Today's vinyl letters look better, longer.
