Click for Ocean Alexander Click for Abeking Click for Burger Click for CL Yachts 99X Click for Abeking
Catamaran Adventure Planned
Discussion in 'General Catamaran Discussion' started by swift, Feb 25, 2023.
  1. HTMO9
    HTMO9 Senior Member
    It is very hard to tell from distance wheather a used boat advertised by a broker is a good one or not. According to brokers, their boats are always pure gold. You have to start with a survey.
    If that pretty heavy boat is doing 5 to 6 kts in the tradewind, the hydro generator will not deliver very much power. The other other problem with the bottled gas will be, what kind of system is it. What type of connection, what pressure, etc. On the other side of the pond You might not be able to get a replacement bottle at all. And carrying several of those "gasbombs" in Your storage areas as spares, is not very safe either, as the storage may not be ventilated by gravity. Means, leaking gas will not leave the storage by itself, it will build a combustible mixture and with the smallest spike, it will eventually send the whole boat into the orbit. I would never take that risk with my family.
    I am a big fan of single fuel boats and the safest fuel for boats is still Diesel. Even the little cannister for the petrol of the outboard engine of the tender needs propper storage. The boat, that has recieved some damage from the hurricane, definately needs a decent survey before paying that price and starting such an adventure with it.
    The distance from Florida to the Canaries, following the tradewinds, it is basically 3.400 NM. At 5 to 6 Kts You will need appp. 24 to 28 days for that leg. And this is open water with no refuelling stop or the possibility of topping up Your fridges. And this will not include any safety margin for periods of calm winds.
    Have look at some more boats, find the one, You like the most and than have it surveyed. With propper planning and equippment it will be definately the trip of Your lifetime. And do not have Yourself talked into trying the northern route via the island hopping. Even if You will survive that route, Your family will never forgive You having taken it.
  2. swift
    swift New Member
    Mamaroneck
    Thanks for input and reply bstet.
  3. swift
    swift New Member
    Mamaroneck
  4. swift
    swift New Member
    Mamaroneck
    Having been reading and looking at a number of different forums and online boat listings. Saw this conversation
    https://www.cruisersforum.com/forums/f48/60-foot-catamaran-for-couple-255393.html
    So you don't have to read all 27 pages.
    Thread started with a person asking about older 60 ft boats,.versus newer to ft odd.
    From different races around the industry longer boats outperform shorter boats, even shorter performance oriented boats.
    So did this advantage added to greater payload of larger boats mean that a person should look for a larger boat, and what would the cost of maintenance extra increases could be on the negative side.
    Some responses included the increased difficulty of docking, increased insurance costs (obtaining of such may also be an issue), increased maintenance costs and increased complexity of systems, though sometimes dual generators, and other systems meant you could probably still manage if one broke down, using the other.
    The cost of purchase of the older longer boat seemed to be stated as similar to the shorter newer ones.
    What say you?
  5. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    Perhaps if the Older longer boat is in current condition. Older longer boat ridden hard and put away wet, as they say, not as likely to be such a sweet deal. Larger longer older boats in need of refit may be more costly, than a shorter newer one.
    I think if you compare an older longer in updated condition (standing and running rigging, maintenance records on propulsion and machinery up to snuff, and all the survey details worked out and the list goes on and on...), then the cruising forum thread folks might be on to something.
