Click for Abeking Click for Glendinning Click for CL Yachts 99X Click for Westport Click for Ocean Alexander
CAT Aftercooolers — and whats Real
Discussion in 'Engines' started by luvtocruise, Jun 24, 2021.
  1. luvtocruise
    luvtocruise Member
    Texas
    Ok— dang it — Ill change ‘em
  2. mapism
    mapism Senior Member
    Sardinia
    In your boots, I'd take the opportunity to install also a fresh water flush connection.
    It was discussed in this thread, from post #40 onward.
    God only knows by how much it will lengthen the life of your CACs (and also of other bits), but pretty sure it won't hurt.
    All the lake boats out there are a living proof that boat engines are happier to live in fresh water...
  3. luvtocruise
    luvtocruise Member
    Texas
    I love this idea — especially since I will/could be away from the boat for weeks at a time — Thanks!
  4. mapism
    Sardinia
    U R welcome, I hope it will prove effective for you.
    It certainly did for me so far, though with different engines.
    But the principle is valid in general, and possibly even more with Cats, considering their recent coolers history.
  5. luvtocruise
    luvtocruise Member
    Texas
    It’s crazy that haven’t come up with a better aftercooler— I haven’t heard of other engines with this kind of problem — so a solution for CAT is out there — or maybe I just don’t understand the issue. Either way I guess every engine has its own downside or flaw.
    My theory is that CAT loves to mount the aftercoolers on top of the motor. My theory is the sea water drains out of them, air is in there along with concentrated salt and allows a lot more corrosion to happen.
    TahoeJohn likes this.
  7. luvtocruise
    luvtocruise Member
    Texas
    That makes sense — a lot of sense. Quickest way to corrosion is salt, heat and exposure to air — the inside of a boat in the summer when its just sitting and the coolers have drained allowing air in….
  8. mapism
    Sardinia
    I'm not saying that your theory is wrong, but it's not like Cat is alone in that design.
    In my 17 years old MANs, whose CACs are also on top of the engine, they were never replaced.
    And based on how they looked when stripped and cleaned a couple of years ago, I would expect/hope them to do their job for many more years - though I'm saying this with my fingers firmly crossed, of course.
    Btw, my last boat before the current one was Cat 3116 powered, and even if those engines certainly aren't among their best ever, they are still working just fine now that they are 26 years old, and with their original coolers.
    I mean, it's not like we're talking of rocket science here.
    In fact, I'm wondering how long it will take before someone will put together a class action against Cat on this issue - unless someone already did and I missed it, maybe...?
  9. Pascal
    The 3412E didn’t have the issue. The ones I ran were 13 years old and had 5500 hours when the boat sold.
  10. mapism
    Sardinia
    My point exactly!
  11. luvtocruise
    luvtocruise Member
    Texas
    3412 is closed loop right as in no seawater?
    CatTech likes this.
  12. Pascal
    That’s why I feel the recommendation for the upgraded design is just a legal CYA. The few car specialists I talked to agree.
    CatTech likes this.
  13. Pascal
    they re like the C32s and I think all other modern cats. Closed cooling system with seawater in the HE, AC, gear and fuel cooler etc
    the 3412s has one stupid “feature” ... the fuel cooler is before the raw water pump and catches whatever debris gets thru the strainers... they re easy too clean every year or two though.
  14. Capt J
    Man's heat exchangers are isolated with rubber o-rings and have no zincs. Something is obviously wrong in the CAT camp regarding the aftercoolers, because you're right, I have MAN's, cummins, etc etc. all running after coolers approaching 2 decades old. SO, is it the zincs themselves interacting with them, the design themselves, the type of metal, IDK.
  15. Capt Ralph
    I mentioned years ago, To many different formulas in the solder used. Ever notice you can not repair a Cat air cooler? The solder will not puddle smoothly or even mix with any thing we tried years ago.
    The assembly vendors flux and drag the air cooler thru a pool of this **** solder. Think of it as older puk metal. Sometimes it last, some times it does not.
    Never found a Cat HE or cooler of any kind have a metal issue. Always that F**&&ng solder.
  16. Capt J
    It should be easy enough to find a new vendor for aftercoolers.
  17. BigChief
    BigChief Member
    CT
    Your engines may have antifreeze cooled aftercoolers which have a longer life than the traditional raw water cooled systems. The aftercooler cores are aluminium in the c12 cats, they are not one piece and bronze like the MANS. If yous are like my c12s the aluminium core gets thin overtime and then eventually leak water into the engine intake and BOOM.
    You can roll the dice and wait and rationalize your decision but the question becomes do you want to spend $$ now and follow the CAT recommendation or put your 100k engine at risk of serious damage.
    Maintenence on the high performance diesels can be expensive but it's part of the equation.....
    I saw your post on BD site, dave is the CAT guy over there. Do a search you will find info on your exact question
    Good luck
    Let's s know what you decide to do
  18. mapism
    Sardinia
    Going a bit O/T now, and I apologize with the OP for this, but you are raising an interesting point.
    There is in fact quite a bit of confusion on MAN's anodic protection (or lack of).
    The reason why there are no zincs anywhere on the engines is that they are bonded with a large external transom anodes, whose main advantage, arguably, is that it's harder to miss when it must be replaced, compared to several pencil anodes somewhat hidden around the engines.
    But this is all well and good, that's the way MANs were designed.
    Where in my experience MAN recommendations clashes with the reality (and I guess it's the reason why you are suggesting that their coolers are isolated) is when they suggest that engines should be isolated from the rest of the onboard DC circuit.
    I've seen plenty of MAN powered boats, built from several different builders, and in all of them, bar none, the engines were earthed with anything else onboard.
    In other words, I've always seen engines and all their bits (HEs and CACs included) bonded with seacocks, domestic DC bank negative, and anything else bonded onboard.
    If by chance you would come across a boat where this doesn't happen and engines are fully isolated, I'd be curious to hear who the builder is, because obviously that depends on the installation, rather than on the engines themselves.
    All that said, back to the point, yes, no doubt there's something very wrong with these Cat components.
    Both the explanations from CR (poor soldering) and BC (aluminum cores) could be valid, but the latter sort of contraddicts what CR said about never having found any metal issues...
  19. bayoubud
    bayoubud Senior Member
    Florida
    Had a Man mechanic tell me Man engines have an isolated ground and bonded to the transom zinc, no aluminum coolers. Seems Cat could easily duplicate that, they have had aftercoolers issues for a longtime. Odd that Cat uses a titanium plate H/E and questionable aluminum A/C on many models?
  20. Capt Ralph
    Any failures around us has always (when autopsied) been a solder failure.
    I don't see much difference between a bonded / non-bonded requirement with MAN engines. Their air coolers have usually drained when not running and when wet, the only stray galvanic currents would be between the engines wet parts. Here is where I hope the alloy air cooler is bonded to the rest of the engine. I'm sure it is just in bolting it down.
