Click for Nordhavn Click for Cross Click for Ocean Alexander Click for Abeking Click for Northern Lights
CAT 32 Aftercooler removal and test..why?
Discussion in 'Engines' started by mallorcaxx, Apr 20, 2020.
  1. 993RSR
    993RSR Senior Member
    Annapolis/ Palm Harbor
    That is a work of art right there. Sending that to my service guys to copy. You don't own the patent do you? :)
  2. bayoubud
    bayoubud Senior Member
    Florida
    Perfect. That's what I'm talking about!
  3. mapism
    mapism Senior Member
    Sardinia
    Nah, I wish I could get a patent by drilling a hole on a lid and sticking a valve on it! :cool:
    PS: by the way, I like salt water to stay outside ALL of my boat, not only main engines.
    For the genset, the a/c chiller and the shaft seals, I made a modification which makes flushing even easier, because they are all directly connected to the boat fresh water circuit, so I can feed all the bits that require salt water also with fresh water, just by turning two valves.
    The reason why I didn't do the same also for mains is just because I feared that the flow from the boat fresh water pump might have been not sufficient. But in hindsight, maybe it was...
    I just can't be bothered to modify it again - the above solution is quick and easy enough for me!
