Click for Burger Click for Cross Click for Walker Click for Glendinning Click for Westport
Capitol transmissions
Discussion in 'Ocean Yacht' started by Boomer, Oct 9, 2018.
  1. Capt Ralph
    Oh. Oil service the other clutch also to help keep your service schedules the same.
  2. Boomer
    Boomer Senior Member
    Seminole
    Definitely doing both at once...mechanic said the marvel stuff has detergents in it that will break up the 30 year old crud that has built up over time
  3. Capt Ralph
    Naw.
    Fresh oil does also. Don't risk swelling any seals till it's time.
    Been driving around still moving my stuff.
    Been thinking my last comment was to short and going to try it again.
    Oil has it's own detergents to help keep things clean.
    You don't want any additives if all is working correctly.
    Bottom line;
    Never kick a sleeping dog. :D:D:D
  5. Boomer
    Seminole
    No dogs will be kicked then sir!
  6. Boomer
    Seminole
    Changed both remote filters on the back of the trannys...little bit of sludge in the bottom of the canister...both trannys had maybe a half shot glass of sludge combined
  7. Capt Ralph
    Rite where the mud should be. Shop vac it out and reassemble.
    Try not to stick anything in there to get more, you may just loosen it and never get the last out. That's why I have a trashed shop vac and small pick up hose (3/4").
    Marvel oil may have loosened it but may have re-suspended it in the oil and spread it every ware again.
    We don't want to stress the seals quicker than need be.
  8. dennismc
    dennismc Senior Member
    Vancouver BC
    I understood the screen cannot be cleaned unless the tranny is pulled, so said the local Cap gear rep.
  9. Capt Ralph
    I found an old PDF Cap Clutch manual.
    Manual says pull the screen every 400 hours for cleaning.
    Some installations may not give you the room to service the screens.
  10. Capt Ralph
    PM me with your real address and I can send a copy. It's about 2.8mb.
    Looks like I downloaded it 1 1 2015 from somewhere.
  11. Boomer
    Seminole
    Well my transmission is going in reverse again for no reason. Only happens when motor and oil is cold...valve body seals were replaced last year...any other ideas? It works fine when tranny is warm...has 100psi according to the gauge when cold. Hardly any pressure when warm at idle but works fine.
  12. Capt Ralph
    Get the valve body resealed. You may have picked some trash or there is a score in the assembly.
    Re-read #27 above.
    Try to get a rebuilt valve body,
    Cylinder and rod all polished up.
  13. Boomer
    Seminole
    Where do you find something like that? Regular old transmission shop?
  14. chesapeake46
    chesapeake46 Senior Member
    Capitol marine gear gear dotcom
    They will hook you up with a repair shop in your area who i think is Chris Jones Marine LLC in Summerville South Carolina . Very knowledgeable on Capitols
    pressure should be 225 to 250.
  15. Boomer
    Seminole
    Way under on the pressure...it is near 0 when hot and about 100 when cold...other tranny shows 200 when cold and about 150 when hot...just pulled the screen on the port tranny and it was clean minus a few very small pieces of metal
  16. chesapeake46
    Correction: 200 at idle & 225 under load.
    Do you know the model of your Capitol ?
    H11200 or maybe H 10200 ?
    The pressure regulator on the pump can be disassembled and inspected for crap.
    Has a big spring inside the you need to be prepared for.
    Not a big deal if you know it's under pressure.
    The direction valve is also pretty easy to take apart.
    The gasket ubder the valve is rubber and re-usable if you take care removing it.
    There are tiny ports there that direct the oil to which ever solenoid pack.
    You can find drawings and explanations at the capitol gear dot com site.
    Need your model # first tho
  17. Boomer
    Seminole
    Thanks for the info...was just looking at their site
  18. Boomer
    Seminole
    Chris Jones called me and gave me a few ideas to try...he thinks the spring may be broke or the pressure is set wrong...got some work to do...thanks for the lead...great people
  19. chesapeake46
    That would be an easy fix.
    Good luck
