Click for Glendinning Click for Walker Click for Abeking Click for Northern Lights Click for YF Listing Service
BW 350 Outrage thruster wiring
Discussion in 'Technical Discussion' started by Pascal, Apr 24, 2026.
  1. Pascal
    Well since MM replaced the thruster with a 12v unit, the issue of the 24v bank is moot. I thought about installing a 12 to 12vdc Victron charger but there is virtually no way to run the wiring from the stern where the batteries are located to the bow. BW installed a wire chase but it is completely full
    How was the bow thruster getting charged to begin with? You can run the wires, I'm sure there is a way without an additional wire chase. Under the gunnels, etc......
  3. Pascal
    Originally the thruster was 24v only charged with a battery charger… but then marine max replaced it with a 12vdc version and didn’t replaced the charger.
    I haven’t found a way to run wires because forward of the aft compartment where the batteries are is the fuel tank under the helm seats. Outboard of that are two fish boxes which are not removable. No way up or
    Down to the gunnels. All sealed. Lousy design
    THERE is always a way to run power from the stern to the bow or access it on a Boston Whaler. The people you are using simply don't know how to look and how to route things. You get to the gunnels from the stern on that boat and over. The speaker wiring is all run outbound of the stringers. If you wanted to island engineer it you could tap onto the windlass wiring and put a Orion XS 12 to 12v DC to DC charger where you can limit amps being charged.
  5. Pascal
    Doing it myself… I have very limited trust in “people” as evidenced by the switch to a 12v thruster…
    this boat has very limited access to anything
    i didn’t think about using the windlass wiring as a power source for a DC-DC charger. Good idea. Thanks!
    Wait a minute; There is a 12V windlass up there??
    Why was this not on our list of assets to begin with?
    Reminds me of our favorite movie;
  7. Capt Ralph
    Just help me get up on a good page;
    Where is the 24v charger?
    Where is the 12V charger?
    Now that we know a 12v windlass is up there, where does it get it's 12v from?
    Don't throw the 24V charger aweigh. I'm using a 40 year old Raritan 24v charger/converter for a bench power supply.
    My back aches every time I think of picking it up off the floor.
  8. Pascal
    The 24Vdc charger is under the floor near the thruster batteries. No longer working since Marine Max changed to a 12v motor and rewired the batteries. I already ordered a 12V ProMariner to replace it
    windlass gets power from the house / center engine bank (two batteries) which is charged by a 12v charger which also charges the port and starboard start batteries.
    now I have another mystery to look into. There are two remote parallel switches to parallel either port and house/center or stbd and house center. For some reason, both parallel switches click back on after like 10 seconds of being turned off.
    I m really not impressed by the electrical system on this boat. For instance yesterday one of the Raymarine Axiom MFD froze up. I couldn’t find any individual CB to reset it and had to use the main breaker that powers all the electronics. Zero redundancy.
    and they used breakers where you have to use a very thin screwdriver to turn off. Lousy design
  9. Capt Ralph
    We will be back down your way in July.
    I always have hammers on board.
    You need me to come by and fix these things for you?
  10. LenR
    LenR Member
    Long Island
    Witch is better for 24v, 2 - 12v batteries together or 1 - 24v battery? And for charging can a 2 bank 12v charger be used for each 12v battery or a 24v charger for the 2 - 12v?
  11. Pascal
    I ve never seen a 24 v battery. I don’t think such a thing exists
    yes you can use a two bank 12v charger, not sure why you woudl do that though.
    I have a 48v bank for my little sailboat and uses 4x12v ProMariner charger, each output connected to a pair of 6VDC golf cart batteries.
  12. Capt Ralph
    Series vs parallel could be a part of your answer.
    Do you require volts or amps to run what you are inquiring for?
  13. Capt Ralph
    I recall some of the fancy lithium batteries come in a single 24v case.
    I maintain a big Hatt with a WesMar 48v (4 x 12v) bow thruster.
    It has a 48v charger.
  14. LenR
    LenR Member
    Long Island
    It is supplying a 24v bow thruster. No charger was installed. There are 2 dead 12v batteries there now that need to be replaced and a charger put in.
  15. Capt Ralph
    Pascal just learned his 24v thruster is really a 12v model. Seems some meat heads really messed up the previous owner.
    It is strange that you have a thruster with NO charger.
    If you have a 24v boat, I would look for a ACR somewhere that tied your thruster batteries to the ships charging system or ships batteries.
    On a thruster, your looking for power, amps, current, watts. Really fast and hard. High current batteries, fat battery cables.
    Two high current 12v batts in series (G31s) should work fine.
    I'm not sure the lithium 24v packages will deliver the high current your thruster can demand. But I am not a lithium guy (can't afford them).
    Now for a charger.
    Fast current out, fast current needs to go back in, preferably with a temp probe since your charging in a confined space (small bow area?)
    Not a trickle or cheap bench charger. Pro-Mariner and above will be required with fuses and PROPER 120Vac wiring.
    I luv spending Other Peoples Money (OPM) but you will thank me once your credit cards are paid off.
    Your north of the line. If you need help, get down to Jax FL.
    We can fix you,,,,, and your boat ☺☺..
  16. Capt J
    Most all of the lithiums, the BMS will not allow them to put out enough amps for a long enough time for a bow thruster. Won't work. A 2 bank 12v charger actually does a slightly better job at keeping each individual battery charged correctly, but a 24v charger would work fine also. SOMETHING has to charge your bow thruster bank.
  17. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Seems odd, no charging at all? Normal would likely have been either a dedicated charger, or one bank of a multi-bank charger would have been aimed at the thruster batteries.
    I haven't yet seen a viable source for 24V (all in one box) LiFePO4 (aka LFP) batteries that offer sufficient cranking amps for starting an engine or running a big thruster or windlass. There's a relatively new "Solid State" thing out there, but their website is a bit all over the map about what those are or are not.
    So in the meantime, absent a decent LFP solution, 2x 12V batteries in series are pretty much the norm, with a single dedicated 24VDC charger (ideally located near/adjacent to the batteries)... or an ACR... or a DC-DC charger.
    -Chris
  18. LenR
    LenR Member
    Long Island
    I bought the boat last July. The boat was a long term project of the last owner. He past a couple years ago. There are a bunch of projects I am picking up the pieces to and completing since July. The thruster was installed but not completed. I don't need it to run the boat but it is a tool in the toolbox that I would like to have working.
  19. Capt Ralph
    Lets stop raiding Pascals thread.
    Lets open a new thread talking more about your boat.
