Click for Burger Click for Walker Click for Delta Click for Nordhavn Click for Westport
Brower 800lbs Hoist replacement
Discussion in 'Technical Discussion' started by Dutch AdB, Oct 16, 2026.
  1. Dutch AdB
    Dutch AdB New Member
    Vancouver
    Looking for a hoist replacement of the RULE V60R UNIT.
    any info, suggestion would be helpful.
    With a new hoist like to install a AMSsteel rope as well, ISO the Stainless Steel cable
    thanks in advance for all your help
    Dutch AdB
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Have you considered taking the original motor into a regular starter repair facility? That's what I did, problems solved and running still after 5 years.
    A whole lot easier than replacing as nothing is a bolt on replacement. Amsteel is a a straight replacement, just be sure to remove any drum or pulley barbs.
  3. Dutch AdB
    Vancouver
    thank you,
    I am considering this… as I did not wanted to take the crane apart to confirm what is really making the noise. ( motor bearing or gears.)
    Trying to find out if there is a replacement with minor modifications and price, before bringing the winch to a shop.
    Thanks for your info.
  4. MBevins
    Windsor On. Canada
    You don't have to disassemble the crane to remove the motor, simply disconnect the "shock absorber", lift the crane arm , there's 3-4 bolts holding the motor and two for the 12vdc connection.
    If it's still running, unwind the cable first , if not cut it. You're done,
    Suggest the second person holding the arm be younger and strong, weights about 80lbs.
    I have a fly so I actually tied it off for safety as well.
    Dutch AdB likes this.
