Click for Westport Click for Glendinning Click for Burger Click for Northern Lights Click for Westport
Black tank on ferretti
Discussion in 'Ferretti Yacht' started by Allythefox, Jun 13, 2014.
  1. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Perhaps your tank is back-filling with sea water? If the thru-hull valve is always open, try closing it to test.
    -Chris
  2. gsholz
    gsholz New Member
    PDX
    89 gallons should be adequate for 4 people. If it fills up that quickly you might have a sticking vacuum breaker in the vented loop in the discharge line which can cause sea water so siphon back into your tank. Cleaning the vent fixed it for me but drove home the fact that it is possible to sink your boat via the holding tank.
  3. Ron Eisenberg
    Ron Eisenberg New Member
    Ft Lauderdale Florida
    I am new to this site and do not know how to reply to two posts that people have made regarding the Black Water holding tank post that I made. Can someone guide me?
  4. Ron Eisenberg
    Please ignore previous post. I see the two posts by Ranger42C and Gsholz above. I will pass this info on to Ferretti. I am hoping that another Ferretti owner with the same tank capacity can chime in. To me it seems that the amount of fresh water being used on each flush is causing the issue. Ferretti says that 1 gal is used per flush. That seems very excessive to me. On my prior 60 Ft Sea Ray, I had a Sealand system and could control the amount of fresh water flushed by how long i held down the pedal. On this new Ferretti, i cannot control the water flow. It is pre set, and because the bowl is always vacumed to empty, one has to do a pre flush for a bowel movement, and then a flush, which uses twice as much water.
  5. Pascal
    89 gallons tank on an an 80 footer is a joke... should be at least twice that.
    What kind of heads do you have? Headhunters are pretty common in that size range, and the duration of the flush can be adjusted.
    That said the tank shouldn't fill up that quickly. Assuming there is an overboard discharge pump make sure it s not back filling the tank. It shouldn't but who knows what kind of pump and set up ferretti used
    In most places you can discharge treated blackmwater (unless in a NDZ). The problem is that over 60/65' the cost of approved treatment system is pretty high
    I had an issue where a head water valve was leaking just a bit. You could not see it without placing paper on the inner bowl.
    It was the cleanest bowl on the ship, maybe that could be a hint.
  7. ranger58sb
    Chesapeake Bay, USA
    There's a "Reply" hotlink in the lower right corner of each message. Clicking that quotes the message to which you are replying and opens the editor for your own contribution. Type away. You can also delete bits from the quoted message if you intend to speak only to a certain point or two...
    -Chris
  8. Liam
    Liam Senior Member
    Malta
    Are your toilets a fresh water or seawater system. In my experience a seawater system is why they smell.
  9. Pascal
    I seriously doubt ferretti installed sea water heads in an 80 footer :)
