Click for Cross Click for YF Listing Service Click for Abeking Click for Ocean Alexander Click for YF Listing Service
Best Underwater Lights
Discussion in 'General Yachting Discussion' started by SRQcaptain, Sep 14, 2012.
  1. CrazyCapizzi
    CrazyCapizzi New Member
    Port Canaveral
    Underwater light info
    I stumbled on this thread looking for info on led lights and what are the best ones available for comparison.
    To be honest I am kinda new to this and on a quest to build the best underwater lighting in existence for my boat. I don't have a name or a website I just want input. That being said, don't kick me off because I have nothing to offer, only questions. I want to know what everyone wants.
    Would you rather ac 12v or dc120v and why?
    Would you rather lower power consumption 50watts, 1.5amp 4500 lumen in a flush built in 2.5" through hull?
    Or higher power consumption 100watts, 3.3amp 9000 lumen with a separate waterproof driver to be mounted inside the boat?
    does flush mount really matter or would you rather surface mount with a 1/2" profile with a 3/4" through hull pipe to run the wiring.
    how about a low cost 10watt 1200 lumen version of the one above
    to answer a previous question about drivers for leds... through my research I found that higher power led chips run off 32v so you need a driver to ether step down the voltage or step up the voltage. and yes leds get very hot quick!
    I attached a picture of my 100w 9000 lumen underwater light creation, water was still lit 50' behind the boat in brackish water. The $150 6w 600lumen led underwater light next to it looked like a toy, only lit 1' in brackish water
    the pic with 5 lights are the 10watt 1200 lumen lights in thinking of making
  2. CrazyCapizzi
    Port Canaveral
    just to make sure the moderator knows I do not make these to sell. it is for my personal boat.
  3. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    My boat had SeaVision SV10 150W Halide Lights when I purchased the boat. One of the lenses was broken and the light wasn't working well so I decided to overhaul/replace both.
    Brett Crawford at Underwater Lights USA was very helpful. He overhauled the electrics on both of my lights and the housing on one of the lights that included the lens. He also quick turned the work so I had the overhauled parts within a week.
    The lights are now like new. These are very high quality lights.
  4. Pascal
    Three months ago I replaced the failed Abyssilites POS with lumitech sea blaze X
    Really like them. Not too expensive and much brighter than the old ones. Have three of them on a 19' beam and they put out a good amount of light. They can be switched to blue when you need to artificially tint cruddy inland waters :)
  5. Ormond Bert54
    Ormond Beach, FL
    My suggestion is to look at the incredible construction of the SeaVision Underwater lights. The housing seems to be milled from solid brass. The rest is milled construction with some ceramic where the electrics mount. The construction no doubt is good at heat dissipation with a thick strong lens. It's not amateur stuff.
  6. P46-Curaçao
    P46-Curaçao Senior Member
    I Agree, have 4 on a 15.9 beam and had 3 on my former boat for 3 years without any problem!
  7. swampyankee
    swampyankee New Member
    portsmouth ri
    Hello i have a 40 foot pacemaker sport fish and i installed ocean led and love them went with the color green and mounted 3 across the transom.get nothing but compliments on them::)
  8. Robb
    Robb New Member
    Mississippi
    I am purchasing a 70 Viking princess and want to add underwater lights. Want to know estimated cost for shipyard to do it all in back and half way up to front. What is best brand and highest power lights
  9. mike Hartley
    mike Hartley Member
    nj
    we added 4 Ocean Led (RGB) on our 76 ft yacht and so far (a year) they have worked great and love them.
