Click for Westport Click for YF Listing Service Click for YF Listing Service Click for Ocean Alexander Click for Westport
Are there reliable underwater scooters?
Discussion in 'General Yachting Discussion' started by P46-Curaçao, Jan 15, 2014.
  1. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    I've used them many times scuba diving. They are used by the general public all the time and have been around for decades in one form or another. In fact you can rent them at many dive locations. I have.
    It's not like you are rocketing around down there unless you are a complete idiot. If you exercise just a little common sense when using one you are very unlikely to get into trouble. And I wouldn't call them "insanely dangerous" for crying out loud.
    I'm sure some one has F-ed up while using them. But I have never heard of it.
  2. HTMO9
    HTMO9 Senior Member
    Seabob F5
    I was on my first day of the Duesseldorf boat show today. On the Seabob exhibition stand, I was introduced to the newest version of the Seabob F5 model. This new 2014 version has many improvements and new safety features. It is much easier and safer to use now.
    The maximum speed settings and max. allowable depth can be preset and encoded, so kids and greenhorns can not exceed set or wanted limits. The clip on gear mechanism has been improved and getting stuck on the scooter will be, if at all, a very rare occasion. Means, most of my concerns are taken care of. A mounting position for a camera and a tender tracking system has been added.
    At slow speed mode and with a 10 ft depth limit (for example), the 2014 Seabob F5, with its permanent 22 lbs residual buoyancy, is idiot proof.
    I still believe, for scuba diving, special dive scooters should be used.
  3. P46-Curaçao
    P46-Curaçao Senior Member
    Could you send some picture of the 2014 Seabob F5, HTM09?
    Vielen dank im voraus!
  4. Old Phart
    Old Phart Senior Member
    I dunno
    Hope this helps:
    Seabob F5 | SEABOB
  5. HTMO9
    HTMO9 Senior Member
    Seabob F5
    That link is perfect and explains it much better than I could do with my humble performance as a photographer.
    As to the clip on gear mechanism: I do believe the new quick release mechanism is almost 100 % fail safe now. The problem I see is, that scooter can do almost 14 Kts and is advertised for a depth of 40 Meters. Also it will not do its full speed at that depth, you have to reach the emergency release lever against that water pressure at depth and speed. Doing this with full scuba diving gear and in neoprene clothing in a panik type situation, might be questionable.
    IMHO, going deeper and with full gear, I would not strap to it and only go in preset slow mode. And for this adrenaline junkie type fun sports, I am to old anyhow :D.
  6. P46-Curaçao
    The F5 looks impressive but, at the end, it's way over the top for me, I just want to have a small reliable device to get me from my boat at anchor to the beach (and back)
  7. HTMO9
    HTMO9 Senior Member
    Seabob F5
    P-46, I fully agree with you. That scooter is far to expensive, to big and heavy for your purpose. But the question of this thread was about the reliability of those scooters :D.
    For your personal need I woud use a little fully inflatable dinghy with a little electric outboard (like the small torqeedo 503 with internal battery). With a two way electrical air pump, that dinghy can be inflated and deflated in just a few minutes and both outboard and dinghy "thrown" into a locker after use. And the whole setup is much cheeper and You will reach the beach with a dry butt :).
  8. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
  9. P46-Curaçao
    HTM09, you're right, and the F5 is too big and heavy for my purpose.
    I have a dinghy, but look for a easy to handle device, for distances like below...
  10. Fishtigua
    Guernsey/Antigua
  11. Capt Bill11
    Fighting chair ejection seat? :)
  12. Old Phart
    I dunno
    Would this make life easier for the admiral?
    http://www.lifting.com/literature/thern/Thern-Reid-Porta-Davit.pdf
  13. Capt Bill11
    What about a 2 person kayak? You could lay it across your swim platform. If you have one. Or perhaps you could get a inflatable kayak or stand up paddle board.
  14. karo1776
    karo1776 Senior Member
    Gone
    Darn... That looks about 300 meters... it's not the Channel nor looks cold to me... you should be able to swim that one... heavens my old broke down 91 year old grandma could do that in and back.
    Just joking... she'd only be 127 now... but wasn't quite mean enough to make that!
  15. P46-Curaçao
    As a former racecar driver, I need a form of propulsion...lol :cool:
  16. P46-Curaçao
    Well, this could be an interestig alternative, we dock most of the time at the stern, so a dinghy permanently fitted at the stern would be very inconvenient (and ugly)
  17. HTMO9
    HTMO9 Senior Member
    Hi P46-Curaçao
    This is the cheapest it will get. Around 500 to 600 US $ and then row, row, row your boat :D.
    B.T.W. Inflating or deflating with the 12V two-way pump will take maybe 5 minutes. And there is no crane needed, even Karos Grandma could lift it out of the water. And if this is still to expensive P-46, are You stingy ? ;)
  18. Old Phart
    I dunno
  19. P46-Curaçao
    Dear YachtFormus friends, why do you all think I'm afraid of getting wet :confused:
    Overhere the water temperature is always around 80F, so no issue at all!
    The senior admiral likes to swim all day, but I´m not...:D
  20. HTMO9
    HTMO9 Senior Member
    Then train her to pull the dinghy and you will get your propulsion :D.
