Click for Delta Click for YF Listing Service Click for Northern Lights Click for Burger Click for CL Yachts 99X
AquaAir Chiller Keeps faulting
Discussion in 'HVAC' started by Danvilletim, Jun 24, 2021.
  1. bayoubud
    bayoubud Senior Member
    Florida
    Odd that it would prevent other types of growth and not barnacles. Chlorine output might be low? No doubt the bromine tablets work, I switched to them after you posted using them over concern with metal corrosion shortly after replacing both chillers.
  2. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    I like the gauge after the pump. That’s a good idea. Got a price of 3300 for cd100 pump which seems like a lot. Going to look at some other options.
  3. chesapeake46
    chesapeake46 Senior Member
    My neighbor was having high pressure alarms on his AC.
    Replaced the raw water pump cause it was old.
    Same alarms.
    Disconnected suction hose, plenty of water gushing.
    Found the interior of the suction hose would collapse when pump was on.
    I do not know the type of hose it was tho.
    So if you are changing the pump, maybe change the suction hose too.
    Had that same problem on a Hatteras main engine a while back. Would get hot at speed.
    Old hose laminate was sucking in and collapsing.
    It does happen.
  5. Danvilletim
    isleton, ca
    Okay. We made it to home port and of course AC is fine at dock. We anchored out for first time ( not on shore power, and engines not on) and faulted the same as underway. Weird.
  6. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Perhaps a power issue with your gen then? Are you getting voltage or Hz drops when starting loads hit your gen ?
  7. Danvilletim
    isleton, ca
    Hertz starts at 61 and drops to 59. Manual says they should be set at 62.5 at no load. Not a big difference. I know shore power goes through charles booster. I guess genset doesn’t? Back on board in a few hours.
  8. Pascal
    Genset output doesn’t go thru isolation transformers. It only affects voltage anyway, not freq.
    Maybe a voltage drop is causing issues but then the system would show a low voltage or power supply error. If freq was dropping during a compressor start you would notice it inside the boat. Plus I am pretty sure that on a boat that size you have freq drive on these chillers.
    maybe worth trying to run the system on both generators to see if it faults. Long shot but at this point ...
  9. Danvilletim
    isleton, ca
    Yes we have Freq drives on the Chillers. Electrical system is complicated by massive 16x 8D inverter system. ( we removed all and replaced with much less as we like AC). I did find a disconnected grounding wire .... not sure where that one goes to.. Can't imagine it would be an issue.
  10. rtrafford
    rtrafford Senior Member
    Vero Beach
    I run 10 tons of chiller, and I'm set up with two Oberdorfer 1hp centrifugal pumps mounted just below the water line with valve controls and an A/B power switch to allow me to switch over periodically from one pump to the other for all of the obvious reasons. I feed them with a 1.5" dedicated through-hull plumbed to a 2" strainer as overkill for the point of raw water restriction. I keep a handful of strainer baskets aboard and rotate them periodically, like weekly during warm months and monthly when cooler.
  11. Danvilletim
    isleton, ca
    Our pump is 1/2 hp... Is there a down side to oversizing the pump? At some point I'd like to plumb in two raw water and two chilled water pumps. I have room but want to figure out this situation first.
    Whats your goto resource for pumps?
  12. rtrafford
    Vero Beach
    Heck, eBay, Grainger, whatever is convenient. The Oberdorfer units are so simple to rebuild and maintain. I just buy parts as needed. Seals, impellers, capacitor, whatever is needed. So simple. And with the spare already in place, I'm not going to be forced into a hot ER to grind through the effort.
    Of course, first you need to know the various part numbers.
  13. Pascal
    Some people argue that too much flow means less time for the water to soak the heat in the coil. I guess it s true if you go way over size. As long as you stay with a pump that uses the same size hose it will be fine
    As I may have mentioned earlier I like Scott pumps. Very solid and reliable. Depco pump is the best source for any pump or pump motor whether AC, oil change, transfer etc. very helpful and responsive.
    we have two Scott pumps on the 116 with valves and a switch as RT suggested. Good set up. Circulation pumps last a lot longer so I m not sure it s worth having two installed. A spare yes obviously... I believe our theee chillers are 60k BTU each.
  14. Capt J
    1/2 HP sounds like it's not enough flow for the raw water side. You need to speak to someone real knowledgable or you need a really good tech. Try calling Ocean Breeze and asking what size pump you should have for the raw water side.
    Are you getting cold air out of the vents when it's anchored? Is your insulation in the engine room sweating? If so, it may be that the chillers are working properly in the engine room, but the chilled water line insulation is insufficient AND cannot overcome the heat of the engine room or you lose a lot of BTU's in the engine room before it even gets to the 1st air handler.
    If you're at anchor in calm water, what's different? The heat of the engine room and you have a generator running. I've always found chiller boats struggled a little when the engine room is hot because the compressors are in the engine room. I keep coming back to the boat is under a/c'd. what's your chilled water loop temperature, at the dock and at anchor? You should be able to get that from one of the displays inside the boat.
  15. Pascal
    And also what temperatures are you seeing for the chilled water loop?
    sometimes if shore power is iffy I have to shut down one chiller. In the evening it’s fine but during the day , loop temp will creep up to from 39/50 to the high 50s and it s not enough to get the boat cold enough. As soon as I turn that chiller back on loop temp goes back down and the boat cools down right away
    on my 53, in winter (Miami) I usually runs just one 36k chiller. Comes May and I need both on during the day.
    monitoring loop temp is important. What do you have ?
  16. rtrafford
    Vero Beach
    I try to match pumps up, be them for raw water, circulation, fuel polish, etc to share the same motor. Then it’s a matter of inventorying pump parts and one motor as spares. KISS.
  17. rtrafford
    Vero Beach
    I’m running two fives in series, total of 10. Loop temps run 44 to 54 on #1 and 46 to 56 on #2. Goal is to keep #2 from short cycling and only running when the sun demands it. I’ll alternate units in sequence periodically to keep use balanced.
  18. rtrafford
    Vero Beach
    My setup is also stacked. My pumps are at the bottom. #1 is roughly sitting atop the water line above them. #2 is sitting atop #1, and all raw water ends up at that upper level, splitting and feeding each heat exchanger with cool water, but combining at the same "elevated" point before running downhill and overboard. That split and lift calls for some extra help with the push of water. I wouldn't want to use less pump than I have.
  19. Danvilletim
    isleton, ca
    I'm leaning towards the generator being the source issue? One 38kw genset was starting fine until 4 days ago... Battery and starter read 12.5 (charger off) and control board for Northern Lights reads 10v. Switching batteries doesn't help.. Load tested battery and its good. So could be a ground issue? And could this issue be effecting the Chillers?
  20. Pascal
    Loose cable, pos or neg, battery switch issue, corrosion.
    No way it could affect the chillers.
