Click for Abeking Click for Abeking Click for Westport Click for Northern Lights Click for Burger
Anchoring Bridles
Discussion in 'General Yachting Discussion' started by Dave Stranks, May 22, 2014.
  1. Delfin
    Delfin Member
    Anacortes, WA
    I think if you look at the windlass manual, they all recommend against putting that load on the equipment. If properly backed, a cleat is going to be quite a bit stronger.
  2. dennismc
    dennismc Senior Member
    Vancouver BC
    Ideal seems to suggest the chain stopper as the reliever. Backing plate would need to be substantial.
  3. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    True and true.
    But the chain stopper gives you, or should I say the chain and anchor, no relief from the snatching effect you get in a blow when the boat comes tight on the chain/anchor like a proper snubber does. That and as has been mentioned the snubber keeps the chain from moving around on the roller and or/hull and making noise at night.
