Click for Nordhavn Click for CL Yachts Click for Abeking Click for CL Yachts 99X Click for Abeking
Anchoring .... Back and Forth
Discussion in 'General Yachting Discussion' started by Mark Woglom, Jan 10, 2014.
  1. Capt Ralph
    Yep, And I criticize them also. Weight savings (anchor, rode and larger windlass), cost (anchor, rode and larger windlass), fashion, on a dock usually every night and younger skippers may not know how to use a second anchor.
    I'm still with Pascal, a proper rigged single anchor should work in most needs. And, it works for us. However, some times on more open water I have dropped a second hook. Bahamian or just a large spread pattern has helped. (Not a storm setup, that's another more serious discussion).
    Our pulpit is the single anchor design from Bertram with a BA Bruce anchor. Horizontal windlass has two gypsy's. We have 3 rode sets available at anytime on the bow. The Fortresses (#2 & #3 sets) are folded down in the forward deck locker (3/4" wrench taped to shackle). Still looking for an original Bertram dual anchor pulpit.
    I also commented earlier about Old Pharts idea and phrased it wrong (again); Not a drone, but a drogue. I'm still looking forward to experiment with that idea when in a toss between wind and current.
  2. Pascal
    Anchor manufacturers have simple boat size ranges per anchor size which are always off by at least one size. If possible I go two size over the recommendation, as long as the pulpit / roller can accommodate it.
    It also depends on the boat and how where you use it. High windage (beam or enclosed flybridge) will definitely require a larger anchor.
    Most all anchors also are rated or list their holding power (in lbs) in addition to boat size. The windlass strength is also a consideration in addition to the pulpit and roller. Whether you have all chain or just a short piece of chain and nylon rode makes a major difference as well in holding power.
    For example:
    http://www.rocna.com/sites/default/files/sizing_graph_pounds.jpg
    http://www.fortressanchors.com/selection-guide/fortress
    (click on selection guide)
  4. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Your anchor should be big enough that people coment on its size when they strolling passed you on the dock. :)
    As to the swinging at anchor issue, it tends to be a function of to much super structure forward in many cases. It's like dart with no flights. If leading the anchor line mid ships doesn't help then there is not much you can do, other than installing a mizzen mast as some one else suggested. :)
