Click for Cross Click for Ocean Alexander Click for Walker Click for Westport Click for Northern Lights
Anchor chain hook / snubber
Discussion in 'General Yachting Discussion' started by Pascal, Apr 1, 2021.
  1. Pascal
    8mm. It worked great. We were out in the Exumas for 7 weeks, anchored out 6 weeks or so... pretty much moving every day. The snuber never jammed and really worked out.
    Yes 84 Lazzara skylounge. Owners are considering and upgrade
  2. mike Hartley
    mike Hartley Member
    nj
    thanks for the info
  3. ThirdHatt
    ThirdHatt Senior Member
    Palm Beach Gardens, FL
    Hey Pascal! Very cool snubber pendant. Mantus makes great products. I have been using their second generation M2 chain hook and it is the best that I have found after being disappointed like you have by many other chain hooks over the years. The Mantus hook releases very quickly, and has never come off the chain. I substituted their duplex shackle for a Dyneema soft shackle.
    My only concern with the snubber pendant is that you have to bolt and unbolt the shackle every time you connect and disconnect. Seems like that would take more time than using the rubber strap on the M2 chain hook, but I guess you could just feed the entire bridle through the loop each time. What are your thoughts?
    Thanks!
    Byron
  4. Pascal
    Indeed I feed the entire line thru the eye. Only takes 15”.
