Click for YF Listing Service Click for Burger Click for Delta Click for Walker Click for Ocean Alexander
Aleution Yacht's Polar Bear; Caught Fire
Discussion in 'General Yachting Discussion' started by travler, May 26, 2010.
  1. RER
    RER Senior Member
    Newport Beach CA
    Welding. At least one downwind boat suffered extensive smoke damage.
    Owner operated vessel. About three weeks ago the boat was driven onto the Zuniga jetty at the entrance to San Diego bay. It was in the yard having that damage repaired when it caught fire. That's a pretty rough last couple of weeks for POLAR BEAR.
    That should've been avoidable......anytime you're welding you should have plenty of fire protection at the immediate area.
  3. RER
    RER Senior Member
    Newport Beach CA
    Yes, heads are being scratched ...and the jetty should've been avoidable too.
  4. Petr
    Petr New Member
    mediterranean
    Wow, that video sends shivers down my spine. Fire on a boat what a nightmare. Hopefully everything will get sorted out for the owner.
  5. Marmot
    I was surprised at that as well. Firefighters have a saying, "put wet stuff on the red stuff" so they tend to squirt a lot of water.
    It is easy to understand why they did not flood the hull, it might have caused the stands to fail and the boat to fall over and that would have created a real mess.
    What I am surprised they did not do (at least in the video) was set up fog nozzles around the boat to keep the radiant heat from damaging other boats or structures but perhaps they did but we didn't see it. It might have been too hot to get on the waterside of the boat to set up fog on that side.
    While shoreside firefighters may not be all that well trained in marine firefighting I bet the ones in SD have had a lot of Navy training and did what they knew to be the best in that case. The boat was literally toast and not worth risking anyone.
    Yeah, I've missed his posts also. He has the most beautiful Avatar of anyone here, as well as a wealth of knowledge.
  7. milo12
    milo12 Member
    Morro Bay CA
    Is the Polar Bear 100% steel constuction?
    If so that fire is very sobering, all that was just the interior burning.
    I guess if you were at sea you would still have a floating steel carcass but the smoke would have killed you if you didnt abandon quickly.
  8. K1W1
    It might have easily got so hot that you were forced to abandon ship before the smoke got ya.
    I think this vessel was a steel hull with alu superstructure
  9. captholli
    captholli Senior Member
    In The Bilge
    Aluminum melts @ 1,200 degrees f and will support combustion @ 2,200 degrees f. I can only assume the superstructure of this vessel is aluminum. I was in a shipyard in Saugatuck Mi. Years ago where two 90 - 100 ft completed yachts were ready for delivery to their owners & were blocked in a shed out of the water for the winter due to lake michigan being frozen, these vessels caught on fire due to a kerosene heater malfunction and the only thing left were the engine and generator blocks and maybe the washer / dryer frames or anything made out of iron/steel. Fire got so hot that it blew huge craters in the concrete floor. There were a few small puddles of molten aluminum on the floor but 99 percent of it burnt or consumed itself. I think that the British Navy found this out the hard way in the Faulklands.
  10. milo12
    milo12 Member
    Morro Bay CA
    Have any post fire pictures been posted? I would like to see if superstructure melted.
  11. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    So where do you expect the liability is in this? If it was caused by welding is it clearly the yard ( assuming they supplied the welders) or is the burden put on the owners insurance?
    Is it typical for a yard contract have indemnification clauses in them?
  12. AMG
  13. Capt J
    If it was caused by welder's supplied by the yard, than it should fall on the yards insurance.
  14. chesapeake46
    chesapeake46 Senior Member
    Does foam spray like water ?
  15. K1W1
    Here ya go
    https://www.youtube.com/watch?v=XTCDqltPc4Y
    AFFF- Aqueous Film Forming Foam is carried on the water stream by a venturi arrgt
    There are two common kinds , Protein Foam a sort of reddy brown colour is corrosive and is made of bulls blood and the other is synthetic
  16. chesapeake46
    That is the explanation I wanted.
    Other videos of the fire look like they are spraying with water but the harbor looks like foam is floating on top.
    Still the water carried foam could add weight to the boat, crushing the stands and tipping, no ?
    Nice video.
    They sound like Detroits.
  17. K1W1
    And isn't that a great sound?
  18. chesapeake46
    It is.
    Like diesel pornography, if you will.
  19. Capt Ralph
    I love the smell of Detroits in the morning. It reminds me of,, Victory..
