Click for Westport Click for Delta Click for CL Yachts Click for Ocean Alexander Click for Burger
Adventures in boat shopping
Discussion in 'General Yachting Discussion' started by RossC, Jun 20, 2023.
  1. Capt Ralph
    Next question, Did either of the surveyors measure the diameter (or radius) of the wheels?
    Any comments of the Wheels?
    Pictures of the wheels?
    Who hired them, you or the sales broker??
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Don't know anything useful, but I'm interested to see what you learn because our most recent WOT test showed some similar results, starboard engine carrying more load than port. Our props were both re-habbed at the same time, although that was at the start of the 2022 season and something may have changed since then.
    For the sake of completeness, I notice you didn't include load numbers for the slow cruise test...
    -Chris
  3. RossC
    RossC Member
    Rehoboth Beach, DE
    So looking at an over-prop situation on the stbd, When we haul in November I would have the props done anyway. Doesn't sound like I need to worry too much about it.
  4. RossC
    RossC Member
    Rehoboth Beach, DE
    Yes, they did measure the wheels and checked everything for true. No comments other than noting that the stbd was just redone. My buyers broker hired them. Engine surveyor said he would check the props and the boost sensor. Nothing that needs immediate attention.
  5. RossC
    RossC Member
    Rehoboth Beach, DE
    They are calling 2000 slow cruise. Here are the cool down numbers after the trial run. Nothing of substance other than fuel flow.
    PORT ENGINE STARBOARD ENGINE
    RPM 550 550
    COOLANT TEMP 175 166
    OIL PRESSURE 29 32
    OIL TEMP 200 203
    FUEL RATE (GPH) 2.4 2.6
    TRANS OIL PRESSURE 330 335
    TRANS OIL TEMP 133 130
    I didn't mean over propped, just more prop than the other wheel.
    It is amazing two props at the same pitch, with 1/4" differences in diameter can run so different.
    It is amazing two props at the same pitch, with a light cup difference can run so different.
    Remember, cup is hand tapped into your props, two different guys, two different days, months,,,, will make a difference in the matching of prop cups or final edge finish.
    Every time I whack a wheel, they both go to the shop.
  7. RossC
    RossC Member
    Rehoboth Beach, DE
    Makes prefect sense. I'm not going to worry about it.
  8. Capt Ralph
    Nothing to loose sleep over short term, It would bug me for a long amount of time. Both engines run more efficient when pulling the same load.
  9. RossC
    RossC Member
    Rehoboth Beach, DE
    So asking was 319k. Offer was 300k and accepted. Post survey we asked for a 5k reduction. Naturally listing broker disagreed with just about everything on the squawk list and won't give a dime. Here is the list. I thought 5k was pretty generous. He was able to get a tech on the nav electronics. They replaced the network hub, a few cables and the AP control head. They also got the upper and lower JL Audio sound systems working.
    Bilge blowers were marked as inop by the hull survey. Broker says they are working, just weak. Master toilet is inop and he can not find anyone to get to it any time soon. I think the shaft between the flush pedal and the ball valve is broken. I can fix it if I can get parts locally (Ft Lauderdale).
    Would y9ou guys accept this list as is. I'm inclined to accept as long as I can close the sea cocks. Without being able to close them I can't even clean out a sea strainer.
    PORT ENGINE AND TRANSMISSION RECOMMENDATIONS:
    1. PORT ENGINE RAW WATER INTAKE VALVE IS STUCK IN THE OPEN POSITION. RECOMMEND FREE VALVE AND EXERCISE REGULARLY.
    2. PORT ENGINE RAW WATER INTAKE HOSE CLAMPS ARE RUSTED. RECOMMEND REPLACE CLAMPS.
    3. PORT ENGINE RAW WATER PUMP IS RUSTED AT SEAL HOUSING AND SHOW SIGNS OF LEAKAGE. NO ACTIVE LEAKS WERE OBSERVED DURING THE SURVEY. RECOMMEND TREAT RUST, CLEAN AND MONITOR.
    4. PORT ENGINE RACOR HAS SEDIMENT BUILD UP ON CENTRIFUGE. RECOMMEND SERVICE RACOR.
    5. PORT ENGINE CRANKCASE BREATHER HOSES ARE DRY CRACKED. RECOMMEND REPLACE HOSES AND CLAMPS.
    6. PORT ENGINE OIL DRAIN HOSE AND FITTINGS AT OIL PAN ARE LEAKING OIL. RECOMMEND REMOVE, INSPECT AND RESEAL.
    STARBOARD ENGINE AND TRANSMISSION RECOMMENDATIONS:
    1. STARBOARD ENGINE RAW WATER INTAKE VALVE IS STUCK IN THE OPEN POSITION. RECOMMEND FREE VALVE AND EXERCISE REGULARLY.
    2. STARBOARD ENGINE RAW WATER INTAKE HOSE CLAMPS ARE RUSTED. RECOMMEND REPLACE CLAMPS.
    3. STARBOARD ENGINE RAW WATER PUMP IS RUSTED AND LEAKING OIL AT SEAL HOUSING. RECOMMEND REMOVE AND SERVICE/REPLACE.
    4. STARBOARD ENGINE EXHAUST RISER LAGGING IS DELAMINATED AND SHOWS SIGNS OF LEAKAGE. RECOMMEND REMOVE AND SEND TO EXHAUST SHOP FOR REPLACEMENT.
    5. STARBOARD ENGINE OIL LINES TO REMOTE MOUNTED OIL FILTER ARE HEAVILY RUSTED. RECOMMEND REPLACE.
    6. STARBOARD ENGINE RACOR HAS SEDIMENT BUILD UP ON CENTRIFUGE. RECOMMEND SERVICE RACOR.
    7. STARBOARD ENGINE CRANKCASE BREATHER HOSES ARE DRY CRACKED. RECOMMEND REPLACE HOSES AND CLAMPS.
    8. STARBOARD ENGINE ALARMED LOW SEA WATER FLOW. RECOMMEND DIAGNOSE AND REPAIR.
    9. STARBOARD ENGINE WAS PRODUCING EXCESSIVE BOOST OVER SPEC. SUSPECT FAULTY WASTE GATE OR BOOST PRESSURE SENDER. RECOMMEND DIAGNOSE AND REPAIR.
    GENERATOR RECOMMENDATIONS:
    1. GENERATOR EXHAUST HOSES ARE DRY CRACKED. RECOMMEND REPLACE HOSES AND CLAMPS.
  10. Capt Ralph
    Your notes above show a boat that has not not been keep up in bristol fashion. Sadly, this is the normal of most boats out there.
    Old hoses are the norm and probably another reason to sell.
    So, What are the comparables selling for? What condition are they in?
    Naw, not even I exercise the my sea-cocks regularly, I do know they are greased up well and will close when needed. Last service; November 2022.
    But my clamps are indeed 10-8. I'm always about checking the bilges. 45 year old boat, I'm there. Just replaced all the hose clamps on my mains.
    Some were recent, the oldest maybe 3-4 years old.
    Master head issues? The owners did not fix that before?? Come on...
    With all that, $5k is not much to ask since the boat was obviously in need of these services before the listing.
    The stb high boost issue may go away when the props are matched. If not, some penetrate oil may help before a real service is needed. It is an external gizmo and some lube and hand exercising may help some more.
  11. RossC
    RossC Member
    Rehoboth Beach, DE
    Sold comps are in the low to mid 300's. Most appear to have original Raymarine electronics. Hard to tell the condition, but I've looked at enough boats to know the perfect boat doesn't exist. Broker is willing to fix the head. Problem is that everyone is a month or more out. I don't really want to wait a month on something I can fix in an hour for a couple hundred bucks.
    I think we are going to accept contingent on ability to close sea cocks. Would suck to not be able to clean out a plugged strainer.
    If I walk away from this one over 5k I could easily spend that on another boat pre-purchase and end up with way more serious issues. My broker has a guy that has spent over $10k on surveys searching for the perfect boat.
    Does anyone know where a guy could get toilet parts in the Ft Lauderdale area?
  12. Pascal
    Sadly these items are pretty much what you ll find on most boats for sale. Yes the seller should accept an adjustment of $5 to $10k but the next boat will probably have similar issues.
    since you mention a pedal, I m assuming the boat has vacuflush. Should be an easy fix, there is a well stocked dealer in FTL, can’t remember the name off hand but it will come up in a search
  13. RossC
    RossC Member
    Rehoboth Beach, DE
    I've looked at worse boats for more money. It is vacuflush. Environmental Marine seems to be the go-to in the area.
    I was going ask about vacuflush. I've never had a boat with this system. Seems like a lot of moving parts. Seems like fresh water fed macerating toilets are simpler. Opinions?
  14. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    I have a strong dislike for Vacuflush after having 2 boats with them. I switched to Raritan Elegance and have been very happy to be rid of the vacuflush and all their issues. As you said a lot of moving parts.
    SeaLion and Capt Ralph like this.
  15. Capt Ralph
    Fix the VC, go home and replace them.
  16. Pascal
    My 53 had been converted to VF in the late 90s when I bought it in 2003. I kept the 3 VFs till about 4 years ago. Yea they could be a little temperamental sometimes but pretty much never let me down. Once in a while the vac pump wouldn’t shut down so I would have to turn off the breaker but they would still work
    Nowadays there are better solutions as electric heads have improved so when the VFs got to the point where they needed full rebuilt I switched to Raritan Elegances. I don’t miss the wondering if the vac pump would shut down :)
  17. ranger58sb
    Chesapeake Bay, USA
    Sea cocks, yes. And I'd guess they'll actually work, with a bit more ooomph! applied.
    But most of the rest seems to me to be stuff I'd want to baseline... along with other similar hose replacements and so forth... on my own dime so I know it's done, when it was done, and done properly.
    MarineSan dot com has Vacu-Flush parts (overnight if you need it), good diagrams, and there are some decent YouTube videos from various people on maintenance.
    I prefer a freshwater electric macerating toilet, but now that we have VFs I can live with it.
    -Chris
  18. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    I did the same conversion. Ditched the VF heads and installed two Raritan Elegance units along with their SEA/FRESH water option. By far one of the best upgrades I've done!! Highly recommend this conversion to anyone.
  19. RossC
    RossC Member
    Rehoboth Beach, DE
    When you guys upgraded to the Raritan, did you use the same holding tank?
  20. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Yes, You plumb the Raritan directly into the existing holding tank, remove all the Vac stuff.
