Click for Westport Click for Nordhavn Click for Delta Click for Northern Lights Click for YF Listing Service
A/C raw water pick up
Discussion in 'Technical Discussion' started by Capt Ralph, Jul 7, 2018.
  1. wdrzal
    wdrzal Senior Member
    You need to know the saturation temperature of the refrigerant your using, pressure is part of this calculation. This is where hot high pressure gas turns to liquid (the condenser). To make sure it stays liquid until it reaches the metering device , at least a few degrees of sub-cooling is needed.
  2. rgrennen
    rgrennen New Member
    Your ideal situation would be to have 1 through hull that that has two baskets and two pumps so that you never lose the system for maintenance or a failure. You just need to find out how much water flow you need for cooling and then make sure your suction line can handle that much flow without becoming turbulent. Turbulent flow will decrease the cooling effect and cause pumping issues.
  3. wdrzal
    Actually, the opposite is true: turbulent flow increases heat transfer. That's why the fins on heat exchangers, radiators , condensers, evaporators etc. have wavy fins, not smooth.
    Ah, er, oh, I don't think so.
    Every bit of material exposed helps transfer heat (or cold). With all the wavy fins you see, there is just a bit more material to conduct & transfer energy (heat) to the air. Further keeping the air path even through out the area of the evap, air cooled radiator or air cooled condenser.
    With a gas (freon) to water heat transfer as on a boat, the smooth flow of water, making smooth and constant contact with the transferring surface is most desirable in the condenser.
    Smooth and even flow of water thru an engines heat exchanger is good also.
    Not to fast or slow, maximum contact and energy transfer to the water and back overboard.
  5. rgrennen
    rgrennen New Member
    Yeah you are 100% correct. Sorry I guess I had a brain fart there.
