Click for CL Yachts 99X Click for Nordhavn Click for CL Yachts Click for YF Listing Service Click for Glendinning
56M Perini S/Y Bayesian Sinks During Palermo Storm
Discussion in 'General Yachting Discussion' started by kevin8tor, Aug 19, 2024.
  1. Maritna_ra
    Maritna_ra Active Member
    Dublin
    The captain has refused to answer prosecutors’ questions during his first formal interrogation.
    That was a great start to shed light on what happened.
  2. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    The Italian Air Force have concluded (or disclosed ) that it was a microburst rather than a tornado,
  3. Steve in SoCal
    Steve in SoCal Member
    From SoCal to Latin America
    That was what I mentioned a few pages back. I think you and I both know the energy of a micro burst as airplane pilots. I do still wonder if the anchor drug the boat under as the time frame on sinking is so short?
  4. RER
    RER Senior Member
    Newport Beach CA
    A dragging anchor is not a set anchor, that’s why it’s dragging. I can’t imagine any scenario where that would take the boat down. Even if it were to reset. And as others mentioned here, I don’t believe it’s ever happened.
  5. Pascal
    If anything a dragging anchor will keep the boat pointed into the wind. There is no way for an anchor to pull the bow down! Except maybe on a 14’ John boat.
    captholli likes this.
  6. BlueNomad
    BlueNomad Senior Member
    At Sea
    Minor point: a dragging anchor during extreme conditions will allow the bow to fall off the wind, to what extent depends on the residual resistance provided by the ground tackle.
    Of course, the bow will not be submerged to any degree during such an event. Even if the anchor(s) were fully set and holding, bow submergence to the point of taking solid water over the foredeck is not a realistic scenario.
  7. Steve in SoCal
    You guys are thinking about anchor drag on an upright boat. From the crew the boat was listing 20-25 degrees for some time before it went over. The crew also said the bow went down first. That really suggests the anchr MAY have had some impact on the sudden sinking. I don't know if you folks remember an AHTS that went to the bottom because of an anchor The Burbon Dolphin
  8. BlueNomad
    At Sea
    With all due respect, stability concerns arising from typical loads experienced during offshore rig scale commercial anchor handling operations have little relevance in this case imo.
    I wouldn't be surprised to see heel angles around 20-25° given sufficient wind strength beam-on, although probably quite unsettling to the crew and guests. The CEO's comments (though undoubtedly in bad taste) have some merit that something else, e.g. flooding, must've accounted for the more extreme heel angles and non-recovery.
  9. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    Form a former Capt., I think down flooding was the most likely cause of the sinking, more so than the knock down.
    The Angle of Vanishing Stability is the angle of heel at which the vessel righting moment reaches zero, meaning that the vessel will not return to upright. Again, I forget the actual numbers for this, but the figures would be around 90 degrees with the moveable keel lowered and 75 degrees with it raised.
    The Downflooding Angle is much more important though in the scenario we are talking about. This is the angle of heel at which water will start to enter the vessel (usually through engine room or accommodation ventilation ducts)… once this starts the vessels is in serious trouble as stability is quickly reduced or lost due to the flooding.
    The downflooding angle for Bayesian was around 40-45 degrees… much less than the AVS. So, unless the vent dampers are closed (which with HVAC systems and generator running they would NOT be as they need to be open for that), the vessel will start to flood rapidly if heeled more than the downflooding angle.
    Actual article is here: https://www.sailingscuttlebutt.com/2024/08/27/former-bayesian-captain-offers-insight/
    Maritna_ra likes this.
  10. Norseman
    Palm Coast, Florida
  11. Capt Ralph
  12. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Since they all ended up in the salt bath, you've gotta wonder what they're collecting.
  13. Pascal
    Most modern phones will survive a salt bath, we ve retrieved guests phones down to about 15’ and they worked fine.
    I wonder what they hope to find… it s not like the crew had time to communicate by phone during the accident and I can’t imagine any of them discussing the sinking by text afterward.
    yet authorities didn’t do any drug and alcohol test!
  14. Norseman
    Palm Coast, Florida
    Yes, very familiar with microburst on sailboats, been knocked over twice but no drama as she popped right up when I steered into the wind. (While holding on and bracing with a leg sideways and the rudder barely in the water)
    Also had micro burst airborne but modern airplanes and modern airports have so much sensing equipment and early warnings that no metal was bent.
    The big one was @ DFW airport when a Delta 1011 crashed and killed most of the crew and pax in 1985. That one was the big wake-up call for downdrafts and microburst and the industry took it seriously and did a lot of research on the phenomenon.
    I spent 15 years of my life flying 747s, lucky as no 747 has ever crashed due to microburst, too much mass in motion according to the experts.
    (In the simulator however we had some close calls practicing the DFW crash)
    As for this thread and the big sailboat: All the holes in the Swiss cheese lined up she just sank really fast.
    I am guessing future BiG sailboats will have automatic locking air intakes when the critical 45 degree angle is coming close, the generators shut down and the emergency power for pumps, steering, controls, etc will be handled by a big battery bank in water proof compartments. Pretty low tech really, submarines has been built that way for 100 years.
    Maritna_ra and Scott W like this.
  15. Steve in SoCal
    In all forms of transportation graveyard legislation/rulemaking is the standard.
    Really unthinkable that the class societies didn't have the vents close automaticly. A simple system even years ago. Yea, saddly all the holes in the cheese lined up on this one!
  16. Norseman
    Palm Coast, Florida
    Yes, the USCG is as guilty as the FAA: Remember the California dive boat that burned, perfectly legal
    to have a death trap as long as a crew member was awake and in charge, but no plan B in case the night watch took a nap, 33 dead bodies..:mad:
    The FAA writing different rest and duty time limitations between pax and cargo pilots inviting abuse from cargo operators, fly till you die. Not impressed.
    At any rate, back to the subject, this huge sailing yacht that sunk as fast as swamped rowboat in a rain storm.
    Not impressed, but hopefully lessons will be learned, present boats modified and future boats improved..
  17. MountainGuy
    MountainGuy Member
    Austria
  18. Maritna_ra
    Dublin
    Here a podcast with Bill Prince...I think there no need to introduce him...
  19. Pascal
    There are still two things that don’t make much sense
    1)- leaving the ER door open at anchor. Why would anyone do that? Two reasons not to: in case of a fire, most of your gas is going to vent out… and you re dumping a ton of hot air into whatever space the ER opens into whether a crew area (smaller boats under 120/130) or a dinghy garage.
    Question to big boat captains: do you allow the ER door to remain open at anchor or even at the dock? I don’t on the 110’ I run
    2)- if the ER vents can flood at a 45 degree angle, wth don’t have automatic dampers? At 45 degree, chances are the gens are going to shut down anyway due to oil starvation so no air is needed in the ER. Seems like a major flaw to me
  20. BlueNomad
    At Sea
    My understanding is that E/R access was limited to the aft bulkhead/corridor crew-only spaces, likely part of the internal 'garage' accessible via the hull side opening. If the E/R door were open, it may have been for ease of access and/or to help dissipate heat, as probably only one genset was running so would be easier/quieter than the main ventilation fans. Genset likely to be reliable NL-equivalent without any history of major malfunction, fire, etc.
    As a side note, I cannot imagine the hull side was actually open at that time/location so very unlikely to be a source of initial flooding.
    I understand there were no openings whatsoever in the E/R fwd bulkhead, other than typical penetrations for services, electrics, etc which would have been verified to maintain WT integrity.
